long start
Old Oct 22, 2012 | 11:46 PM
ballbandit's Avatar
ballbandit
long start
i got an 03 7.3 with 111,000 miles. it was taking long time to start sometimes. i changed the ipr 5 weeks ago and seemed ok since then it was acting a little funny again. hooked telstar up and it said unable to verify connection. thought maybe computer was bad so i had an an extra one and switched it out. truck will start and run fine but computer still says same thing, i cant check anything. codes, injector electrical test, contibution test,etc. any ideas why its saying this? last time i was able to check stuff but now it seems like something went crazy. any input will be great. thanks.
Old Oct 22, 2012 | 11:53 PM
BigAlsPSD's Avatar
BigAlsPSD
Check the fuse for the cigarette lighter, its the same circuit as the power on the OBDII port.
You could check for voltage too.
Name:  Payson's OBDII Data Link Key Off & KOEO Plus Diagram.jpg
Old Oct 23, 2012 | 12:01 AM
ballbandit's Avatar
ballbandit
the fuse was blowed at first no power to tester. replaced fuse then had power to tester. got me puzzled.
Old Oct 23, 2012 | 12:08 AM
BigAlsPSD's Avatar
BigAlsPSD
What tool are you using, and have you been able to connect before with it?
Old Oct 23, 2012 | 11:04 AM
ballbandit's Avatar
ballbandit
its the rotundra telestar. and yes it hooked up to it about 5 weeks ago. i even tried another tester of the same thing and it does it also.
Jason Whatcott
Jun 24, 2019 11:04 PM
angel29
1997 - 2003 F150
Feb 11, 2012 01:40 PM
88f1504x4
Apr 17, 2011 07:26 PM
twistedcherokee
Jun 9, 2010 06:21 PM
jtbutler
May 10, 2010 12:07 PM
