South FL AE??
Old Apr 14, 2011 | 05:47 PM
88f1504x4's Avatar
88f1504x4
Powerstroke Doctor
South FL AE??
I'm wondering if there is anyone near west palm with AE?? My truck had to come home on a flat bed yesterday with a no start. I battled a long start for a couple of weeks, changed my cps, my icp, and rebuilt my IPR. Nothing helped it I replaced my IDM last tuesday and that fixed it. Its been awesome for a week now this. First thing I thought was IDM went bad I went and had it tested and it was fine they still switched it out with a new one for me anyways. Thats didn't change anything. I am so at a loss and have no way to get it to my buddy with a scanner.
Old Apr 15, 2011 | 07:43 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Here is a bump Kenny........ Good luck.
Old Apr 15, 2011 | 07:03 PM
88f1504x4's Avatar
88f1504x4
Powerstroke Doctor
Thank you. After trying and trying for two days I finally got it to start drove it 5 miles came back and shut it off and won't start again. I had a check engine light coming on and going off but it ran perfect. I hooked up my superchip to at least see what the code was and now that won't even turn on.
Old Apr 16, 2011 | 07:49 AM
miller_feed
Check your fuses. Look for the one that powers the PCM and cig lighter to see if it is blown or not making a good connection. On my truck it is fuse #30, but I think it is a different fuse on the '02. If that fuse is blown, unplug the fuel heater plug on the back of the fuel bowl, then change the fuse and see if it will start.
Old Apr 16, 2011 | 08:37 AM
mueckster's Avatar
mueckster
Were you able to read the codes? What were they?
Old Apr 17, 2011 | 07:26 PM
88f1504x4's Avatar
88f1504x4
Powerstroke Doctor
I finally got it to run and it is running better then ever for some reason exhaust sounds better, it feels more responsive. I did do the hutch mod and I believe it was air in the line. My code now is p1316 yet again I am going to go do the injector buzz test again tomrrow and see what I get. I am noticing when I start it up its blows blue smoke as long as i let it idle until I give it a little bump it stops. I am wondering if this could be an injector o-ring or cracked cup.
