Sponsored by: Real Truck
How to
Old Oct 22, 2012 | 10:29 PM
wildhoggs6885's Avatar
wildhoggs6885
Question How to
Does anyone know how to remove the radio antenna on a 2012 f250. I need a shorter one because it hits the cross beams of the parking garage at work. Thank's
Old Oct 22, 2012 | 11:49 PM
Firekite's Avatar
Firekite
Originally Posted by wildhoggs6885
How to
...create a thread with a meaningful title? Glad you asked. Why not give a summary of what you're looking to know in a few words? Try something like "Removing radio antenna" for example.
Then again from someone who doesn't know how to unscrew a radio antenna, maybe that's asking too much.
Answer: lefty loosey
Old Oct 23, 2012 | 12:35 AM
EXv10's Avatar
EXv10
Welcome to the forum but please give a more descriptive title next time.
Old Oct 23, 2012 | 06:30 PM
wildhoggs6885
Yea your wright, what was I thinking. You must not have a 12 or you would know what i was talking about. Thank's anyway
Old Oct 23, 2012 | 06:37 PM
EXv10's Avatar
EXv10
Don't give up on the forum, lots of good stuff in here.
Old Oct 23, 2012 | 07:24 PM
bridge's Avatar
bridge
Sick 'n Tired
Its too dark out now to check mine out, but it probably just unscrews. I use to have the same issue in my F150. I just removed the antenna, removed the ball at the end of it (you can pull it straight off with a pair of pliers), removed 2 inches, and reattached the ball. I don't suggest removing any more as the antenna would then be lower than the roof line. The antenna acts as an early warning system to prevent a very costly roof repair.
Old Oct 23, 2012 | 07:37 PM
wildhoggs6885
WOW thanks. The ant has a cover over the base so I can't get a wrench on it. Im not as dumb as the the first person may think, just don't won't to mess any thing up.
Old Oct 23, 2012 | 07:45 PM
bridge's Avatar
bridge
Sick 'n Tired
Belay that...it might not just unscrew. Its hard to tell from the diagram.
  1. Remove the RH cowl side trim panel.
  2. Disconnect the antenna.
  3. Disconnect the antenna-to-antenna lead-in cable electrical connector.
  4. Release the grommet.
  5. Remove the antenna mast.
  6. Remove the RH cowl vent grille.
  7. Using a suitable tool (such as a flat-bladed screwdriver), remove the antenna mast boot.
  8. Remove the 3 screws and the antenna.
Old Oct 23, 2012 | 10:35 PM
wildhoggs6885
Thank's sounds like more trouble then it's worth. When I get a day off ill give it try. Who would of thought all that for an antenna.
Old Oct 23, 2012 | 10:59 PM
Quad Racer's Avatar
Quad Racer
It sounds similar to my 08. There are just three little screws that hold it down under the cowel. It doesnt look hard to me. Pop the hood and you can look bach and see it.
Old Oct 24, 2012 | 08:36 AM
Firekite's Avatar
Firekite
It just unscrews, guys. Pop up the little rubber boot and unscrew it. I've had mine off for a while now.
gadiedrick
Dec 17, 2016 01:15 AM
UWMtriebs
Dec 23, 2009 03:19 PM
pancake
New York Chapter
Aug 25, 2007 02:50 PM
Ruikee
Jun 2, 2007 10:15 PM
ffmechanic
Escape & Escape Hybrid
Nov 10, 2006 10:17 PM
