Front Suspension
Old Nov 14, 2012 | 03:29 PM
davbeisner's Avatar
davbeisner
Is there another name for trackbar? Couldn't find one at carquest...
Old Nov 14, 2012 | 04:16 PM
MC5C's Avatar
MC5C
It's probably a dealer only kind of part. I searched and found no suppliers for a stock type part other than Ford. Aftermarket ones are all adjustable, for use on lifted trucks. It is also known as a panhard rod, but Ford calls it a track bar. It's the bar that goes from the chassis at upper right, diagonally down to the axle lower left, and it centers the axle in the truck.
Brian
Old Nov 14, 2012 | 06:33 PM
Rusty Axlerod's Avatar
Rusty Axlerod
Third item down from the top here:
2006 FORD F-250 SUPER DUTY Parts - Tousley Ford Parts Depot
Probably one of the best prices out there ($100.38).
Old Nov 14, 2012 | 08:30 PM
davbeisner's Avatar
davbeisner
Thanks, Rusty! My dealer here wanted $307 for all the parts plus another 4 hours labor to replace them... don't know how long it will take to replace those three parts, but there's no way 4 hours can be right!
Tousley had all three for a total of $187 in parts and I'll do the work myself...
Just out of curiosity (aimed at our Ford techs here)... is it acceptable for a dealer to charge more than MSRP for an OEM part? All the prices they had on their quote were $10-15 above MSRP as per Tousley...
Old Nov 16, 2012 | 05:10 PM
davbeisner's Avatar
davbeisner
Ok, parts from Tousley should be here early next week... Is there anything I have to do in the way of adjusting things, or just install them and take it in for an alignment? How long should swapping trackbar, trackbar ball joint, and steering dampener take a novice mechanic with a good understanding of mechanics and a good collection of tools?
Old Nov 16, 2012 | 06:52 PM
Rusty Axlerod
Sure man, glad to help! I read somewhere Tousley's is cost plus 10 or 15%. I still use my local dealership sometimes but if I have time to wait I order from them. Shipping is generally pretty quick also.
Old Nov 16, 2012 | 11:19 PM
BLADE35's Avatar
BLADE35
Originally Posted by davbeisner
Track bar
Track bar ball joint
Steering dampener
Alignment (after install of above parts)
None of these parts would normaly cause Vibration maybe a Bad Dampner maybe
Tire wear and alignment/pull one way or other would normaly be what you get if Above said parts were Bad
You should be able to change all these no biggie
As Far as the Inner Axel Tube seal if your going in that far may as well do Balljoints to personaly I would wait till you need BallJoints unless you drive in alot of water thats deep enough to get in there. There is an Updated part for that. But pretty common to see those axel seal hanging there not doing anything
I bet the vibration will go away with new tires that are balanced
Old Nov 16, 2012 | 11:25 PM
BLADE35's Avatar
BLADE35
. I jacked up the front today and used a pry bar to check for worn u-joints but they were all tight. ?
Did you mean BallJoints???
Thats not how you check U~Joints or I dont anyway
Old Nov 17, 2012 | 09:36 AM
davbeisner's Avatar
davbeisner
Yeah, I probably did mean ball joints... On my last truck I had some bad front end parts and that's what they mechanic showed me how to do. He probably said ball joints, but I remembered u joints... Still learning all this stuff!
Old Nov 17, 2012 | 07:55 PM
BLADE35's Avatar
BLADE35
Probably What?????????????????????????????????LOL
Dave Here how I do It for BallJoints
Pull the Tire and Push & Pull on the steering Knuckle/Hub Top and bottom there should be No Play on the Verticle Line its easy this way because you do Not have to Overcome the Weight of the Tire for thjis method since the tire is OFF
I know the Guys at the Shops Lift the Car and take a Bar and tweeek it to check for play But unless your Good At it Odds are you wont tweek it right anyway and 1/8th inch play is Bad
As Far as the U~Joints you Spin them to check leave truck on ground and in 2WD
Turn right and spin
turn left and spin
Straight ahead and turn
Noteing any Binding or Play as you turn
Old Nov 17, 2012 | 09:53 PM
davbeisner's Avatar
davbeisner
Cool, thanks Benny!
Old Nov 17, 2012 | 10:38 PM
BLADE35's Avatar
BLADE35
you can also check the Tierods while tires are off by Push & Pulling on a Horizontal Axis
Any play in any Steering Component is Bad 1/8 inch is Alot
all the BallJoints and Tierods are Wedge Shaped so as you Torq the Castle Nut it draws the Parts Tighter together
appletun
Aug 23, 2018 11:00 AM
tbear56657
Apr 5, 2017 09:11 AM
Petik
Jul 9, 2016 03:38 PM
lbrowne
Jun 7, 2011 10:32 AM
nighthawk285
Offroad & 4x4
23
May 13, 2009 06:27 AM
