Tight Steering
Old Oct 22, 2012 | 12:02 PM
HOUSE1224's Avatar
HOUSE1224
Tight Steering
Here is my issue - my steering box was leaking badly. Thought of replacing the seals but time did not allow for that so I replaced it completely with a rebuilt unit from AZ. The leak is stopped but the sterring feels tight. Like it only has 1/2 power steering. Turned wheel back and forth several times to make sure all air was out of system, fluid level is correct. Any suggestions on why just changing the box would make it hard to turn??
Old Oct 22, 2012 | 12:08 PM
Freightrain's Avatar
Freightrain
Welcome to the forums.
Depending on how loose your worn out box was will determine if the replacement is too tight or just not worn out like your previous box.
When rebuilt, they set the preload/lash on the box with the screw/jam nut on the top cover. It can be set too tight, thus making it hard to steer(and wear itself out prematutely).
Or is it a pump pressure issue?
Old Oct 22, 2012 | 12:13 PM
HOUSE1224's Avatar
HOUSE1224
I didnt have this tight issue before I replaced the box. I guess if it was worn out it could have taken less pressure to operate, right?? Is there a way to test or set the pressure?? Should I just change the pump? Any help is appreciated...
Old Oct 22, 2012 | 02:48 PM
Freightrain
Can't really give you any specs or what to do with pump. There is a relief spring you could change and increase pump to make it easier, but I would do that as a last option.
bobbytnm
15
Sep 22, 2018 09:13 PM
Myfreeford
Mar 26, 2011 08:07 PM
tjdad62
Dec 28, 2010 03:44 PM
cwpowell
Jun 22, 2010 01:17 PM
tinsmith
Mar 31, 2004 06:54 PM
