another CEL question
Old May 19, 2003 | 09:49 PM
Jason Does's Avatar
Jason Does
Question another CEL question
I've never seen the cel on my truck and was once told that Pin 17 on the computer was where the power for that originated. The question I have is this, can I put a test light on the pin connector like a normal circuit? Is there anyhthing between the pin and the light that I want to watch out for?
Old May 20, 2003 | 08:56 AM
Ken00's Avatar
Ken00
Have you checked the bulb?
Old May 21, 2003 | 01:41 AM
Jason Does's Avatar
Jason Does
Yes, I checked the bulb........ I had the dash apart once and swapped it with a good one.
Old May 21, 2003 | 01:00 PM
Ken00's Avatar
Ken00
You will need to run the pinpoint tests, check your mail.
Old May 21, 2003 | 11:01 PM
Jason Does's Avatar
Jason Does
Maybe I didn't make myself clear........ I've never seen the check engine light (cel).........
Old May 22, 2003 | 09:25 PM
Ken00's Avatar
Ken00
I understood your question, the infomation I sent should help, did you get it.
Old May 22, 2003 | 11:10 PM
Jason Does's Avatar
Jason Does
I got the mail but other than the resistance test on the cluster/harness I didn't find it relavent to my problem
Old May 24, 2003 | 06:16 PM
Ken00's Avatar
Ken00
Sorry, I don't recall exactly what I sent you. If I didn't send you the pinpoint test QA send me an email so I can attach the procedure.
