Carburetor leak
Old Oct 21, 2012 | 07:28 PM
TheRedPheonix's Avatar
TheRedPheonix
Carburetor leak
The carb on my 76 f350 with 360 is leaking gas out of the vacuum port for the distributor advance. What is going on?
Old Oct 24, 2012 | 09:05 AM
rustywheel68's Avatar
rustywheel68
this is outside my usual area, but since nobody else has chimed in...
how much fuel are we talking about?
i'm wondering if either-
the carb is running super-rich and fuel is somehow getting into the vacuum port on its way down towards the intake
or
maybe there's a crack somewhere that is allowing fuel into the vacuum port?
Old Oct 24, 2012 | 03:19 PM
big vann's Avatar
big vann
What kind of carb?Could be a stuck needle/seat or mechanical obstruction/damage.Was there any work done just prior to the leak?More info would be helpful.
Old Oct 24, 2012 | 04:13 PM
TheRedPheonix
It's the stock carb so maybe a motorcraft 2100? The fuel literally pours out of the vacuum port when the truck is running. Only work it's had done in that area was the base gasket got replaced but there wasn't anything that got hit or changed on the carb itself.
Old Oct 25, 2012 | 11:18 AM
big vann's Avatar
big vann
Maybe a 2150?Either way it sounds like a rebuild is in order.Don't run the truck like that as a fire is bound to happen.One of my trucks caught fire from a leaky fuel filter.I was able to put it out quickly though.I carry a 3 lb fire extinguisher in any vehicle I drive.Ya never know.Rebuild kits are cheap and once you take the carb apart the problem should be evident.I'm still thinking stuck needle in the seat.
Old Oct 25, 2012 | 08:20 PM
TheRedPheonix
Yeah, i know what you mean. All three trucks have this issue right now. I think ill take apart the one at home and see whats what inside there first. Its probably all the same problem.
Old Oct 30, 2012 | 11:46 AM
TheRedPheonix
After tearing into one of the leaky carbs it seems that it is dumpin fuel into the engine and when the throttle is closed the gas backs up and comes out the vac advance hole in the passenger side barrel. What now?
Old Oct 30, 2012 | 12:26 PM
rustywheel68
i think you are back to Big Vann's suggestion- sounds like the needle isn't seating properly to shut off the fuel flow.
Old Oct 31, 2012 | 07:14 AM
big vann's Avatar
big vann
You're going to have to rebuild the carb.They're pretty simple to do.Just get a good rebuild kit and follow the directions.Clean it very well and make sure all the new parts go in.Remove the float and check that it doesn't have any leaks by placing it in a container of water to see that it floats.If you see any air bubbles when it's submerged,it has a leak and needs replacing.
morlogs
Dec 27, 2011 07:29 PM
deronyv8
Jul 7, 2011 11:54 AM
sammycooks
13
Mar 1, 2010 04:56 PM
hifooy07
Aug 29, 2009 07:42 PM
LTTLMAN
Feb 12, 2005 04:00 PM
