Electric cooling fan?
Old Oct 21, 2012 | 11:13 AM
Fyrhosr's Avatar
Fyrhosr
I have a 1951 F1 with a flathead and was considering putting a electronic cooling fan in her. Has anyone done this and if so any recommendations? Are they fairly simple to install? Thanks in advance.
Old Oct 21, 2012 | 07:39 PM
52 Merc's Avatar
52 Merc
What are you looking to gain by doing this? Are you 6V or 12V? Generator or Alternator?
Old Oct 21, 2012 | 07:54 PM
Fyrhosr's Avatar
Fyrhosr
Wayne,
We just converted her to 12 volts with alternator. Basically looking to keep her cool when driving around town and cruising.
Old Oct 21, 2012 | 11:50 PM
51PanelMan's Avatar
51PanelMan
Add a fan shroud. It should help more than you think. An electric fan hooked up to a switch that you can control is also a good idea.
BTW, how did the door latch workout?
Old Oct 22, 2012 | 12:04 AM
Thed's Avatar
Thed
Quoted for truth.
Old Oct 22, 2012 | 11:29 AM
52 Merc's Avatar
52 Merc
As long as your cooling system is operating properly, your stock fan setup should function just fine. If you have a true overheating issue, it's better to find and cure the cause than to start chasing a problem with band aids. Once you pass 20 mph there's more air flowing through the rad than the fan can pull. Unless your top speed is 5 mph and all you'll be doing is driving in parades, I'd save the money and effort for something more important. That's my 2c.
Old Oct 23, 2012 | 08:09 PM
das54's Avatar
das54
check out post #56. https://www.ford-trucks.com/forums/1...l#post12161850
my neighbor gave it to me. It is the perfect width and the top and bottom bracket were simple and easy to make. I have a much different situation than you do. I would have had to fabricate a cowl. I'm sure this thing cost a pretty penny and I wouldn't pay for one if there was a simple cowl available to solve the problem.
Old Oct 28, 2012 | 10:53 AM
Fyrhosr's Avatar
Fyrhosr
Ilya, You really think the shroud would make a bit of a difference? As far as the door, the handle seems to be holding its own, it is still sagging and sloppy. Thanks again
Old Oct 28, 2012 | 11:00 AM
51PanelMan's Avatar
51PanelMan
A shroud does make a difference because it contains and directs the air better going to the radiator. Also, check to make sure that the hood has an air deflector and that it's in the correct position.
Sorry to hear about the door handle. I couldn't find anything else wrong with it besides what I found and repaired.
Someone could make a small fortune if the door latch mechanisms would be reproduced.
Old Oct 28, 2012 | 11:27 AM
3golfjack's Avatar
3golfjack
One draw back I've seen to using a electric fan is that some electric fan motors seem to be loud. I just like hearing the motor/flat head more so then a humming electric motor.
ALBUQ F-1's Avatar
ALBUQ F-1
Originally Posted by Fyrhosr
Ilya, You really think the shroud would make a bit of a difference? ...
I'm running a 3-bladed fan from a car on my truck, with a shroud, and it runs at the proper temp even in traffic on 90+ deg days. Without a shroud the air recirculates from behind the fan to the front side.
Old Oct 28, 2012 | 11:58 AM
Fyrhosr's Avatar
Fyrhosr
Ilya,
My hood deflector is in the farthest back position(toward the cab), is that correct position?
Fyrhosr's Avatar
Fyrhosr
I found a shroud on eBay, delivered will be @ $60. Might invest in that.
Old Oct 28, 2012 | 12:01 PM
51PanelMan's Avatar
51PanelMan
With a flathead V8, that is the correct position. $60 for a shroud is not an unreasonable investment.
Don Bordeaux
1997 - 2003 F150
Jun 7, 2018 07:49 PM
RadioControlGuy85
Oct 7, 2016 10:17 AM
maddogken
Aug 30, 2009 06:05 PM
Axel F
19
Aug 19, 2007 11:31 PM
daolred78
Apr 9, 2006 11:20 AM
