steering colum igniton
Old May 19, 2003 | 08:46 PM
yellowknifer's Avatar
yellowknifer
Question steering colum igniton
I have 1993 F150, could anyone tell me if it is simple to remove the igniton from the steering colum, and do i require any special tools
Thanks
northofsixty5(No Email Addresses In Posts!)
Old May 19, 2003 | 09:43 PM
steve83's Avatar
steve83
It's easy. Just put the key in RUN, push a probe up into the only small hole in the bottom of the column, then pull the whole lock cylinder out. The new one should already be in the RUN position with the button pressed in, so just insert it and turn it to ANY other position. That link has plenty of diagrams.
If you're talking about the ignition switch, you need a Torx driver the right size (T-25, I think) and you have to remove the lower column shroud, which requires removing the instrument cluster bezel. It's all at that link.
