Sponsored by: Real Truck
diesel vs gas
Old Oct 20, 2012 | 06:53 PM
cjag1973's Avatar
cjag1973
diesel vs gas
does diesel really get better fuel millage?
and if so how much better.
thanks
Clint
Old Oct 20, 2012 | 07:53 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Yes.
But no.
My friend has an almost equally equipped V10 and I have a 7.3. With me right behind him he gets about 11mpg while I get 16mpg.
Old Oct 20, 2012 | 07:57 PM
Misky6.0's Avatar
Misky6.0
thanks
Clint
Depends on 2 vs 4wd and axle ratios and tires.
I get 21 on long 600 mile trips not towing.
The v8/v10 ex folks get 10-14 hiway.
I get 15-18 around town.
Old Oct 20, 2012 | 08:00 PM
Hotpocket's Avatar
Hotpocket
i would say it depends on the setup..my 5.4 super cab short bed 4x4 373s can get over 20 mpgs highway at 45, 18 at 55, 16ish at 60 to 65 and about 15 at 70 all according to scan gauge 2
Old Oct 20, 2012 | 08:03 PM
MisterCMK's Avatar
MisterCMK
Diesel gets better mileage, has more power and as a result is faster. I've seen 18.5 @ 70mph and I have a heavy foot.
Old Oct 20, 2012 | 08:07 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
It does not depend on the set up at all. Thats like saying a Prius only gets better mileage because its a hybrid car. Comparing 2wd manual SRW to a 4x4 auto DRW is not the same thing. Apples and oranges.
The question is which ENGINE gets better mileage, not which CONFIGURATION gets better mileage. So in a CCLB 4x4 automatic SRW, a diesel will get better mileage than a gas motor in the same truck.
Old Oct 20, 2012 | 09:29 PM
EXv10's Avatar
EXv10
I thought it was a given that diesels get better MPG.
Old Oct 20, 2012 | 09:46 PM
Hotpocket's Avatar
Hotpocket
that is what i meant by setup..the 5.4 is a weaker motor then the v10 and a cc lb is alot heavier then a scsb or single cab lb so the 5.4 will prolly get similar mileage to a v10 in that setup because the 5.4 is always straining..but in the short wheelbase trucks the 5.4 is not straining as bad and
tends to get pretty decent mileage..so the "setup" would be my deciding factor based on mileage..in my experience with fleet 7.3s they get about 14 mpgs in the cclb and and the gassers get about 11 cc lb (v10 and v8) ...but my scsb consistently gets 16 ...i don't think a comparable diesel gets THAT much better to justify the expense...it just depends what config he wants
Old Oct 20, 2012 | 11:08 PM
Tom's Avatar
Tom
That they do. Like everything else in this world it comes with a fee. At the moment a $0.50/gallon surcharge as well as the added cost, complexity, and maintenance expense of owning a diesel.
Whether or not it's worth it depends on the situation and budget. I've had two diesels in the past and am currently a very happy V10 owner. And Trey, I'd love to know the conditions where you get 16 and your buddy gets 11. Just this afternoon I was pulling nearly 12 MPGs towing my 3,500 lb boat back from the shop!
Old Oct 20, 2012 | 11:17 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Freeway from Ventura, CA to Pismo Beach, CA, 55mph the whole way. Granted he had a trailer, but it weighs 900lbs dry and it only had a quad in it. He also had a quad in the bed, but so did I. Really I dont think it would have contributed too much to a "strain" on the motor. I was carrying maybe 300lbs payload and he was towing 1200lbs?
I'm not trying to undersell the V10, that thing has more than proved itself. It never gets the maintenance it needs and has never complained. I'm just simply saying shes a thirty gal
In addition to her 11MPG she also enjoys about 2-3 quarts of oil every 10,000 miles.
Old Oct 21, 2012 | 07:41 AM
LSchicago2's Avatar
LSchicago2
Diesel will get better mileage. Will it cost less per mile? That could go either way. If we are talking newer trucks, probably not. Too many other added costs with the diesels. In my case, I save money now using V10's.
Old Oct 21, 2012 | 08:00 AM
BigPigDaddy's Avatar
BigPigDaddy
You're CHEATING!
Drafting obviously skewed the numbers!!
Old Oct 21, 2012 | 08:16 AM
sammy77's Avatar
sammy77
You're getting 12mpg with 4:30 gears towing 3.5K?? That's outstanding, I never saw over 9mpg towing that weight with 3:73's. That was only reason I went to a diesel.
Old Oct 21, 2012 | 08:28 AM
Tom's Avatar
Tom
Yup, but this was also the first trip out with my new transmission thermostat. So the trip home with the boat had the transmission at 175-180° instead of the relatively frosty 120-130° it used to run, and the transmission is more efficient when it's up to temp. Seems a bit far fetched to me that it would have a meaningful increase in gas mileage, but I was about 1 MPG over what I usually am yesterday, so I don't know.
Old Oct 21, 2012 | 08:37 AM
acf6's Avatar
acf6
With 35s, i typically get 11-12.5 driving around town/some hwy, but that is extremely LIGHT driving, rarely over 2300rpm. Highway i can get 15-16 if i try, with stock tires i could pull 17 sometimes, and 13-14 around town
