good combo?
Bottom line, these trucks are heavy and require torque to move them. The 302 doesn't have the stroke to create the kind of torque needed to make these trucks either quick or good for towing. If you are looking to buy, why would you want to limit yourself to a 302? It costs exactly the same to build a 351W as it does a 302, so why would you spend the same money to get less?
But then again, we're not talking about towing. We're talking about moving 4000 lbs down the road, and doing it fast.
This is why I'll agree and say that you can get a LOT more for the same amount if you'd build a 351 Windsor instead of the 302. With the 351 Windsor, I'd just stick a stock rebuilt C6 behind it. The torque comes in earlier with the extra stroke that the 351 offers. Throw in a towing cam, an aftermarket intake, a 600 CFM 4bbl, and a set of long tube headers and you'd have a pretty decent truck that would get up and move when you wanted it too. Also, with the 351, you could get away with going down to a 3.55 gear rather than a 3.73 or a 4.10, due to the extra torque.
Remember, even without the higher stall converters and stuff that you can put in, the C6 doesn't have a lockup torque converter. This means that when you're driving, 3.55 gears will feel like 3.73's due to torque converter slip. It simulates lower gearing. A higher stall converter really only belongs in a race vehicle in my opinion, not a street vehicle.
With a street truck, you would want your peak RPM to be 6000, and power from off idle. You'd want peak power from 2000 to around 5000 rpm. A good towing cam, intake, and long tube headers will accomplish this. Do some mild port work on the heads and you'd be even better off. Then run the most advance that she'll take.
A 351 Windsor will also bolt up to a 302 transmission/bellhousing.
Personally, I wouldn't even use the C6. I'd pick a good 4-speed.
But, it is your money and this obviously isn't what you want to hear.
The 302 would do decent in town for play, but don't expect to be able to pull out on the highway at 65 miles an hour and cruise with the C6, 3.55 or higher gears, and no lockup torque converter or overdrive. It wouldn't be a great offroad combination either.
At 340 horses pushing a 4000lb truck with that transmission and gearing, you'll likely only see about 15 mpg, if you're lucky and drive no higher than 55 wherever you go. Probably closer to 12 if you try to make it run on a highway.
Then, if you blow it, your gas mileage will REALLY drop.
For what he's wanting to do, just ignore the towing part.
A 2000 RPM stall converter with a roller motor making 340 horses at HIGH rpm is not a good towing combination, and will make almost no bottom end torque that would be necessary to get a 4000 lb truck moving.
I could see the 340 horse roller 302 with the 2000 RPM stall in a Fox body mustang that has been tubbed with a roll cage and some weight shed, but not a 4000 lb truck. This is why Gary and I recommend the 351W.
Like you said... it sounds more like a semi-racing toy than a daily driver. Nothing driven on the streets needs a 2000 rpm stall converter.
If the OP really wanted too, he could get a 347 stroker kit to put in his 302 that would make it better for a truck, but that stall converter with the C6 and high gearing will still not work in favor of being in a truck.
But, you don't need to change your plans that radically. The 351W will bolt up just fine to your C6 and puts out a lot more torque than the 302 for the same money. Or, you can stroke that to 383 or 408 and have even more torque. Top it with a Performer intake and carb, not the Performer RPM, and you will have a lot of power to get it moving.
And, the C6 is a good, solid transmission but it does rob you of some power. However, if you have a strong engine you won't lose too much. But, the high stall torque converter isn't what you want in a truck as the weight of the truck and its load, its wind resistance, and the potential to tow something will cause the converter to slip more than the stock converter at all times. That causes heating and poor MPG. Either stick with the stock converter or go with something like the Hughes Performance Tow Master.
