HELP!!! 2003 6.0 Zero Power!!!
Old Oct 19, 2012 | 03:48 PM
kudunk86's Avatar
kudunk86
I have a 2003 F250 151,000 mi. with the 6.0. I was having hot start problems so I changed the HPOP, ICP and IPR. Truck ran great till a few weeks later it wouldnt go over 50mph, then 45mph, then 20mph, now 5mph.I have changed all my filters, The stainless high pressure fuel lines on the block (Just in case they were blocked), dropped my fuel tank and cleaned it (little dirty but not bad), Had my FICM tested and it came back fine. It wont rev over 1500 RPM and when I do rev it up there is some (not much) black smoke that come from one of the exhaust pipe behind the motor. Turbo sounds great. No white or blue smoke. Took the EGR valve out (it was a little dirty but was not stuck so I just cleaned it and put it back in). Changed the batteries. Not throwing any codes. Still having the same problem. Also it idles great but will not start again if you let it run for 5 min. Someone PLEASE give me some tips. Thank you in advance!!
Old Oct 19, 2012 | 04:17 PM
wulfman's Avatar
wulfman
What about your injectors ? I just did same as you new HPOP , IPR , ICP , and 5 injectors . My pump was on it the way out and the injectors were leaking where the oil rail pops on causing the hot no start . I would also check all connections and plugs you never know .
Old Oct 19, 2012 | 06:19 PM
bismic's Avatar
bismic
Where did you say the black smoke is coming from?
Old Oct 19, 2012 | 06:48 PM
cheezit's Avatar
cheezit
any codes? icp connector damaged/full of oil ?
Old Oct 20, 2012 | 02:12 PM
kudunk86's Avatar
kudunk86
I have not done anything with my injectors yet. The black smoke is coming from somewhere between the firewall and back of the motor. I can't pinpoint the side it's coming from I think it may be both because on both sides of the motor the firewall has the black suit building up on it. Icp and pig tail are new. No codes. If there were problems with my injectors would I be blowing white smoke??? I really appreciate the help guys.
Old Oct 20, 2012 | 02:16 PM
brickie's Avatar
brickie
Loosen the up pipe and reconnect you have a major leak back there somewhere. It could be a busted flex pipe but you will figure that out soon enough.
Old Oct 20, 2012 | 04:22 PM
kudunk86's Avatar
kudunk86
Ok I will try disconnecting the up pipe and reconnecting. Will a busted flex pipe cause me to have absolutely no power?
Old Oct 20, 2012 | 04:30 PM
mustang_309's Avatar
mustang_309
I would say yes because instead of the exhaust being forced through the turbo it leaks into the engine compartment
Old Oct 22, 2012 | 11:55 AM
kudunk86's Avatar
kudunk86
Thanks for the help guys I will post back as soon as I try this!
Nelsoneddy
Feb 25, 2018 05:35 PM
alangray
Oct 16, 2016 11:05 PM
Moordoom
Feb 24, 2012 06:28 PM
rascal810
Jul 2, 2010 06:25 PM
stvneil
Oct 3, 2006 08:44 PM
