Sponsored by: Real Truck
5.4 engine issue....
Old Nov 13, 2012 | 06:46 PM
Hotpocket's Avatar
Hotpocket
Originally Posted by Crazy001
I like your thought about place possible coolant leak, but that would be a rare failure.
But I have Bosch plugs in mine and it runs just fine. Never have heard a good explanation as to why non-motorcraft plugs can cause problems.
agreed...i have had ngk iridium plugs for 120k miles with no issues
Old Nov 13, 2012 | 10:11 PM
wizkid00104's Avatar
wizkid00104
What about the O2 sensor? That is something that is required to heat up for proper function.
A long shot, but what about the fuel filter?
My Ranger does the exact same thing and I believe it is due to a vacuum leak in the brake booster. A Vac gauge could help you diagnose this part.
Old Nov 13, 2012 | 11:05 PM
99f350sd's Avatar
99f350sd
Old Nov 14, 2012 | 03:44 PM
JayFan's Avatar
JayFan
I'm going to change the fuel filter just for *****s and giggles and see if that does anything. Eventhough I just changed it about 5K miles ago.......
Old Nov 14, 2012 | 03:46 PM
JayFan's Avatar
JayFan
Originally Posted by 99f350sd
I agree. Either that or coolant in the cyl. Very hard to diag..
How long does it take after stop to happen again?
Again its hard to diagnose. An experienced mechanic might have a much better chance at finding out whats wrong by just listening to how it runs.
or not running..
Dick
It happens basically everytime the truck is started......doesn't matter if it's hot or cold........
Old Nov 14, 2012 | 04:51 PM
redford's Avatar
redford
FTE Leadership Emeritus
You may want to read the link about the upstream O2 sensor.
Old Nov 14, 2012 | 06:38 PM
99f350sd's Avatar
99f350sd
As far as I know the o2 sensors have no effect until the engine reaches a certain temp.
At least thats how it used to be..
Dick
carlsson
Jan 10, 2012 01:00 PM
HammeredFlat4
Modular V8 (4.6L, 5.4L)
Jan 24, 2011 05:12 AM
Nightintruder
Aug 30, 2010 06:46 PM
schocker
Sep 14, 2007 07:29 AM
vanman250
1997 - 2003 F150
Sep 2, 2007 03:27 PM
