Get one of those precut 2'x2' thin plywood from HomeDepot and zip tie it to the fan side of your radiator.
Exactly.. I have lots of plywood laying around so that's what I did. With a manual trans I'd just remove the rad but with an auto you have the trans cooler lines connected as well so rather mess with rusted fittings and risk damaging the lines or the rad a piece of plywood is easier.
I'm going to get the 24" extension as Diesel_Brad said but this idea is interesting. I have a tin plate in the cab where a manual shifter would go. I wonder if I can remove that and get to the bolts easier. I'm gonna try.
If you have that plate where the shifter should go, then you got it "made in the shade!" Not many trucks have that plate. I wish mine did even though I made one. Yes, definitely go for it by taking off this plate. It also makes it a ton easier when getting to the tranny coolant lines.
No need to remove the trans tunnel plate, just long extension and a swivel socket.
These trucks are roomy and the bolts are easy to reach. Newer trucks are harder, but still don't need to pull the transmission. The most you would ever have to do is pull the crossmember and use a jack to lower the trans to gain access to the upper bellhousing bolts, but you don't need to do this on an older truck.
Ford likes to make their torque converter bolts out of relatively soft metal. I always make sure to use a good 6 point and make sure its on square.
I usually put a couple pieces of cardboard in front of the radiator, don't always need to, but its cheap insurance.
When going back in be sure to do like dieselbrad says and have the torque converter all the way back, and having the bolts lined up fairly close to the flexplate holes makes life easier.
There is no way to get to the two top bolts between engine and tranny without removing the Plenum or lowering the tranny. My performer Plenum is much taller than stock but I couldn't get to those bolts without taking off the stock Plenum either. I didn't take off the trans tunnel plate because I had some wires going through there but I'll look at it after I remove the motor and have room to look
The motor is ready to come out now. Just did as I always had. Was hoping to find a shortcut
I use a long extension and an impact to remove the top two transmission mounting bolts. Let the transmission rest on something towards the front though to help support it.
The plate on the trans tunnel is the way to go. It still takes a heck of an extension with that route, but it gets you on the bolts straighter, and applies to power more directly.
If I remember right I used a swivel impact socket and two? long extensions. It was pretty easy...or I'd remember exactly what I had to do. Those damn manifold to downpipe nuts are the ****ty one. Get them glowing red then hit with an impact, but they still suck.
That's why I loved going to headers. Both my manifolds were cracked, so I unbolted them, then smacked them with a small sledge...no more manifolds...
I can definitely see how it's possible to reach the two top bolts via the trans tunnel plate. I have my trans raised because the engine is out but when the engine is in, those bolts are a straight shot.
My problem now is I don't think I can get the motor out without removing the Plenum. The motor has to first come up, out of the mounts before it can go forward. Could I remove the mounts from the motor and then move it forward?
