oil filter question
Old Oct 18, 2012 | 10:15 AM
davbeisner's Avatar
davbeisner
Exclamation oil filter question
Ok, so got all the parts I needed to do this oil cooler replacement and I'm ready to start today. However, I realized that I forgot to buy a new oil filter. None of my local parts stores can order in motorcraft filters. My parts store I use most carries the Wix filters. Don't know what NAPA carries. I've read a lot about not using anything but motorcraft. I need the truck this weekend so I can't wait on Tousley to ship me one at this point (wouldn't get to me till Monday) and my closest Ford dealer is 90 minutes away and I have no excuse to take a company vehicle to that town to get one. What are my options?
Old Oct 18, 2012 | 10:21 AM
BPofMD's Avatar
BPofMD
Veteran: Navy
You have NO options... do NOT use the WIX. Check with NAPA - do not use a "will fit". You don't have a WalMart?
joe blow's Avatar
joe blow
****DISCLAIMER*****
You're not supposed to use anything but OEM!!!!!
With that said, It is up to you my friend. You know as well as I do millions of people use a NON RACOR/FORD filter everyday with no issues. Hell, I used a NON RACOR many times before I realized the importance the the dimensions of the filter plays in the system. IF YOU ABSOLUTELY NEED THE TRUCK AND HAVE NO OTHER OPTIONS AND CANNOT GET AN OEM FILTER use a different filter until you get the right one then pop the new one in.
People will probably crucify me but in all seriousness, how many people have used a NON RACOR filter and had "0" issues?
Just my opinion.
Old Oct 18, 2012 | 10:23 AM
joe blow's Avatar
joe blow
double post......................sorry
Old Oct 18, 2012 | 10:31 AM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
Call all the parts stores and see if they have the Fram CH9549.
Old Oct 18, 2012 | 10:52 AM
davbeisner's Avatar
davbeisner
Ok, I will check for that fram. Closest Wal-Mart is across from the ford dealer 90 mins away!
Old Oct 18, 2012 | 10:56 AM
davbeisner's Avatar
davbeisner
My oil is only at 3500 miles... I just assume it has to be drained so may as well be changed. Can I just use my old filter for a couple days then change it.out? Should I put the old oil in if I do that or run new oil through the old filter?
Old Oct 18, 2012 | 11:03 AM
amdriven2liv
That is an option, not over the change intervals. Just be very careful!!! Keep it clean. Then stop at first place to get a new one, and change it on the street. (filter that is)
Old Oct 18, 2012 | 11:15 AM
joe blow's Avatar
joe blow
I was under the impression that FRAM was the bottom of the barrel in regards to filter construction and quality?
Old Oct 18, 2012 | 11:47 AM
94powerstroke's Avatar
94powerstroke
do you heave a truck parts store near by we use nothing but luberfiner 2017 filters or donoldson filters on our fleet all our 6.os have between 200 to 300 k miles and no engine / oil related failures
Old Oct 18, 2012 | 11:52 AM
69cj's Avatar
69cj
donaldson makes the air filters for the 6.0. Not the oil or fuel filters. That's Racor.
Old Oct 18, 2012 | 12:05 PM
Cowboy65's Avatar
Cowboy65
I order all of my oil & air filters from Diesel Filters Online. Better service and prices than my local Ford Dealership.
If you willing to gamble the cost of a new engine go ahead and run an aftermarket filter. If it's not worth the gamble then stick with OEM (Motorcraft or Racor)
Ford 6.0 Liter Turbo Diesel Truck Filters, Air Filters, Oil Filters, Transmission Filters And Glow Plugs - Diesel Filters,Additives,brake rotors, and brake pads for Chevy, Dodge and Ford Diesel Trucks
Old Oct 18, 2012 | 12:20 PM
Rusty Axlerod's Avatar
Rusty Axlerod
If the old filter/cap is the correct one I would unscrew it, let it drain, and bag it. After repairs and servicing it up with new oil, I'd swap the filter ASAP.
Getting ahold of a Fram element (if you have the right cap) would be a better choice but be aware they may have changed the design. If the Fram comes with a plastic adapter piece in the box, skip it and use the old filter.
Old Oct 18, 2012 | 12:55 PM
94powerstroke
donoldson oil filter number P550528
Old Oct 18, 2012 | 01:32 PM
69cj's Avatar
69cj
I didn't mean that Donaldson may or may not make one. I meant that Racor is the OEM supplier and the Donaldson would be an A/M filter.
