Wiring Issues
Old Oct 18, 2012 | 07:02 AM
ungerp's Avatar
ungerp
Wiring Issues
Well, I am at the wiring phase and with an original wiring diagram the only thing I know is that the low, high beams and high beam indicator are correct. I have an aftermarket column and thought I had it wired correctly, but last night while testing brake lights. I had the left rear and the two from park lights come on, no right rear. I can get all four park lights to light when I pull the light switch and then this. Still no directionals.
The diagram that I am using does not show directions for the '55, but since all lights are dual filaments I am sure this can be done. Can someone advise?
Thanks,
Pat
Old Oct 18, 2012 | 07:06 AM
EffieTrucker's Avatar
EffieTrucker
Phantom of the Phorum
Will this help?
You'll still have to figure out what the colors should be for the wires in the column.
Old Oct 18, 2012 | 02:35 PM
53FOPAR's Avatar
53FOPAR
Most of the after market columns use the GM wiring system.
Horn Switch - Black
Left front turn - Light Blue
Right front turn - Blue
Hazzard - Brown
Turn flasher - Purple
Left rear turn - Yellow
Right rear turn - Green
Brake Switch - White
Old Nov 1, 2012 | 11:46 AM
ungerp's Avatar
ungerp
Still at it.
Is it normal on these old trucks to have the park lights go out when you pull the switch to turn on the headlights?
Still working the turn signal issue, but working through this methodically.
Thanks,
Pat
Old Nov 1, 2012 | 04:32 PM
GreatNorthWoods's Avatar
GreatNorthWoods
Originally Posted by ungerp
Still at it.
Thanks,
Pat
That depends on your light switch. If you are using an old switch the parking lights are separate. If I remember correctly, OEM light switches were changed starting about 1963 so that parking lights were on with headlights. Before that they were on separate internal circuits. I remember modifying a 57 Chevy light switch may years ago so that the parking lights would come on with the headlights...
Old Nov 1, 2012 | 05:02 PM
3golfjack's Avatar
3golfjack
Still at it.
Thanks,
Pat
The front parking lights will go out but the rear parking lights should stay on. Turn signals are always fun to work on.
Old Nov 1, 2012 | 06:02 PM
homade's Avatar
homade
Make sure everything is grounded really good, you'll have more ground problems than anything.
jayrock67f100
25
Nov 9, 2016 04:25 PM
Gertie-The '49 F2
Sep 23, 2013 12:44 PM
silvertonguedevil
Sep 14, 2010 08:07 PM
IronWorker3
Jan 10, 2005 11:07 PM
Andysutt
13
Nov 5, 2003 07:14 PM
