'76 highboy rebuild... with a cummins
Old 08-01-2014, 08:00 AM
Rogue_Wulff's Avatar
Rogue_Wulff
Rogue_Wulff is offline
Originally Posted by Krewat
Couldn't you at least grind off the "Dodge Ram" from the turbo output ?
Originally Posted by gsb15
Haha i figured it was kinda more insulting to leave it on, the dodge truck was all used up so the engine had to go into a 13 year older ford.
Plus I'm going to add an intercooler before too long.
I am doing the same swap in my truck, 89 12V and NV4500, into 1980 F150 2wd.
Not going with an intercooler, at least for now. I am debating whether to remove the "dodge ram" on the air horn, or leave it there. Would look better without it, but has great potential for allowing plenty of jokes about how poorly built those early dodge trucks were....... 120K miles, 2 dash fires, and then the frame broke. Have to put the engine in a Ford, in order to stand a chance of wearing out the engine, before the chassis......
The swap looks good.
Old 11-02-2018, 02:16 PM
Dan Vosberg's Avatar
Dan Vosberg
Dan Vosberg is offline
Im currently swapping my 76' with a 12 valve as well. I like what you did with boxing the frame and fabbing up a new cross-member. Im doing some of the fab work this weekend and I have the frame boxed. Im wondering how much clearance from the top of frame to the top of the member is needed to clear the 5.9? Thanks!
Old 02-03-2019, 08:58 AM
JohnRoss2233's Avatar
JohnRoss2233
JohnRoss2233 is offline
Looks good - I'm also busy building a truck. Always seems to take longer than expected!
Old 02-08-2019, 09:50 PM
baddad457's Avatar
baddad457
baddad457 is offline
finally getting around to uploading some pictues. lots of progress in the last few months.
cleaned up and painted the under the cab section of frame, had to fix the cab mounts, they had the usual under the bushing rust.
rolled it outside and hoisted the cab back on
back inside, ready to start fabbing
bolted the system together
cut the cross member for clearence
fit the engine
bolted the front clip back together to set the spacing, i cant belive how nice it ended up fitting. no more than an inch spacing front to back.
drive shaft will be pretty short
i decided to keep the 89 style engine mounts, i fabbed these up to bolt to the stock ford bolt holes. i positioned the engine basically where the 360 was, more to the passenger side.
me making sure the mouts are sturdy.
after pulling the engine again i got to work on the x-member, i decided to box the frame and start from scratch.
frame painted and mounts installed
engine back in and bolted up. finally feeling like it might actually come together
now is the fun time, putting everything back together. installed my brake lines, i bought the stainless kit from bronco graveyard. fit awesome except for one line having the wrong fitting.
i adapted the dodge clutch system, made a doubler plate either side for strength.
added a mounting point to the ford pedal for the pushrod.
Thats all for now, next up is to work on the engine, need to do the killer dowel pin fix, re install the injector pump and line, and then get on doing the exhaust and turbo set up. should keep me busy
That clutch master plate isn't going to be big enough to keep the rest of the firewall from flexing. I know from experience. You not only need thicker plate but a larger area to absorb the pressure your foot is going to exert on the firewall everytime you engage the clutch.
Old 02-08-2019, 09:55 PM
ford390gashog's Avatar
ford390gashog
ford390gashog is offline
Good call but few years late.........
bad_habit_F350
16
06-02-2020 10:54 PM
dads1977
S. California Chapter
01-15-2017 06:16 PM
magicsac1366
17
06-17-2013 08:07 PM
drey04
Michigan Chapter
13
07-25-2012 07:57 AM
1974SuperCabF250
Montana Chapter
10-29-2010 03:30 PM
Quick Reply: '76 highboy rebuild... with a cummins
