FRONT END NOISE WHILE DRIVING.
Old Oct 17, 2012 | 07:14 PM
RODEOMAN's Avatar
RODEOMAN
2009 F-150 4X4 XLT. Have noise like a bearing cage coming apart. Sounds like l/front wheel area. With cruise on, noise comes and goes. Tap the brakes and noise does not always go away. At a lower speed when the 4x4 is engaged, noise goes away. Front wheel not loose, bearing appears to be ok. No diagnostic come on. Puzzled.
Old Oct 18, 2012 | 06:56 AM
D8chumley's Avatar
D8chumley
Resident smarta$$
I have had dirt/rocks etc make similar noises on my work truck F150 ( from driving around the jobsite), maybe try going real fast in reverse (maybe 15ish?) and jump on the hooks hard. I have had it where I needed to repeat a few times to dislodge the dirt. HTH
Old Oct 18, 2012 | 08:09 AM
Swiper's Avatar
Swiper
If the noise goes away when in 4x4 i would guess it is your IWE.
probably a vacuum leak or bad iwe.
just a guess.
Old Oct 18, 2012 | 10:37 AM
meborder's Avatar
meborder
swiper may take the cake on this one.
there has been a rash vacuum leaks showing up in the lines for the front hubs, iirc.
https://www.ford-trucks.com/forums/1...elerating.html
take note, i missed the nail in that thread
good luck!
Old Oct 18, 2012 | 06:06 PM
shortride's Avatar
shortride
If you have a lift kit or any modifications to the suspension system you might want to check all of the mounting nuts and bolts. Check lug nuts, drive shaft u-joints and anything you can see and lay your hands on.
Old Oct 25, 2012 | 09:56 PM
RODEOMAN's Avatar
RODEOMAN
Thanks for all replies. The Noise was the result of a vacuum line having a break at the actuation solenoid mounted on the right side of the radiator shroud. Used a hand vacuum pump and thru process of elimination found the leak. Made repair and set to go. Thanks again.
huntingloco
2004 - 2008 F150
May 26, 2018 07:41 PM
Roadtriptruck
Jun 14, 2016 12:34 PM
dieseldrew
2009 - 2014 F150
Oct 21, 2015 12:21 AM
Blown281USMC
2004 - 2008 F150
Jun 1, 2011 07:30 AM
76fordboy
Feb 26, 2001 08:55 PM
