Plastic Fender (Rub) Pull-Back Mod
Old Oct 17, 2012 | 06:32 PM
ToMang07's Avatar
ToMang07
So, being the genius that I am, I had an idea today when I was in True Value... and I decided to spend the $10 on hardware.
I purchased 2 bolts, 2 large washers, a flat-backed nut, small chain (1' is more than enough) and 2 eye/hook turnbuckles.
Entire "mod" took 10 minutes.
Basically, put the bolt through the washer, then through the existing hole in the plastic inner fender, right in the bottom-rear middle.
Widen the end of the chain just enough to slip the bolt through, then put on the flat-nut.
Cut the chain as short as you can while still able to hook to the turnbuckle.
I used the open end of the turnbuckle to an existing hole under the truck (see pics) opened the other end of the chain and attacked it to the eye-side of the turnbuckle.
Tighten, pulling back the fender. Easy as that.
I went off-roading in my fields being sure to hit the bumps at full-turns, not even a slight rub. I just wish I thought of this months ago BEFORE my fenders started rubbing through.
Anyway, no more concerned looks when turning in parking lots!
Old Oct 17, 2012 | 06:43 PM
BigAlsPSD's Avatar
BigAlsPSD
Looks good, nice write-up, pretty rusty truck, lol.
I just drilled 2 holes and used a cable tie through the hole to pull them back.
Old Oct 17, 2012 | 07:01 PM
ToMang07's Avatar
ToMang07
Yeah....winters in New England mean lots of Salt.
Old Oct 17, 2012 | 07:04 PM
VegasFordSD's Avatar
VegasFordSD
nice write up, good idea!
A little late for me, and the plastic is the least of my worries
Old Oct 17, 2012 | 08:14 PM
joegebff's Avatar
joegebff
Gone Fishin for Mark
I just did the plastic delete mod, makes it easier to clean the inside of the fender.
Old Oct 18, 2012 | 02:04 PM
HH60FE's Avatar
HH60FE
Pop rivets for me. gona hold em in for a long time.
Old Oct 18, 2012 | 09:27 PM
bigb56's Avatar
bigb56
So, being the over engineering type that I am I did the same thing only it took me a few hours.
Instead of a washer I cut some sheet metal big enough to cover the damage. Then I put 2 carrige bolts thru it and bolted a piece of flat 3/16" to them behind the fender well. This plate has another hole in the middle which has a piece of 1/2" all thread thru it which is bolted to a bracket I welded up and bolted to the frame. By turning the nuts on the all thread I can pull the fender wells back however far I need to, then I lock the nuts together to hold in place.
Old Oct 18, 2012 | 09:33 PM
pin8246's Avatar
pin8246
I looked at this post a few times, and still cant figure it out. Are you guys rubbing, or what? If so, what size tires, and lifts you running to rub?
Old Oct 18, 2012 | 09:37 PM
BigAlsPSD's Avatar
BigAlsPSD
Levelled 2.7" with 35's for me. Yes rubbing slightly, also had to space my front bumper out after flexing the suspension a little more.
Old Oct 18, 2012 | 09:42 PM
bigb56's Avatar
bigb56
I am running these 285 BFG Rugged Terrains with no lift, they rubbed on the driver side from day 1. I only drove from the tire store to the house before doing the mod, already had a hole worn in it..
Old Oct 18, 2012 | 09:43 PM
pin8246's Avatar
pin8246
Ah ok. Just wondered, because the only thing that rubs on mine is the 35's hitting the leaf springs at full lock.
Old Oct 18, 2012 | 10:22 PM
ToMang07's Avatar
ToMang07
I have X-Codes (6,000lb) which gave me 2" over my worn/flat U-Codes. (4,800lb) springs, plus a 2" leveling kit (mini-spring pack) and 315-75-16E Duratracs on 16/10" Rims.
Old Oct 18, 2012 | 11:08 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Mine said bye bye when I took a DREMEL to them. But I'd like to replace them and just pull them back.
Old Feb 1, 2014 | 04:48 AM
jetdoc's Avatar
jetdoc
This is exactly what I want to do. Do you still have this set up? Do you like it? I have a set of 16x10 Weld rims already and planning to get the dura tracs as well. I'm getting the parts together now to rebuild the front end so I'm going to do this all at once. Thanks!
Old Feb 1, 2014 | 07:56 AM
ToMang07's Avatar
ToMang07
Sure do, and I love it!
