power steering conversion
Old Oct 17, 2012 | 12:59 PM
cayce73f100's Avatar
cayce73f100
Ive got a 73 f100 with manual steering. I took the old gear box out and bought a new ps gear box with a parts number D1TR 3550 BA. it is a 4x2 truck. The new gearbox is supposed to be out of a 79 model. Heres the problem, I knew the pitman arm would be different, but it is very hard to find them, and I need a parts number for a pitman arm that will go with my new gearbox. Any help would be appreciated.
Old Oct 19, 2012 | 07:58 PM
lasthighboy's Avatar
lasthighboy
are you sure your old pitman arm wont fit on your new box? i thought it would. all of the 2wd box pitman arms should fit. shouldnt be hard to find
Old Oct 20, 2012 | 01:39 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by cayce73f100
I've got a 73 F100 2WD with manual steering. I took the old gearbox out and bought a new P/S gearbox with a part gearbox housing ID engineering number D1TR 3550 BA
The new gearbox is supposed to be out of a 79 model. Here's the problem, I knew the P/S pitman arm would be different, but it is very hard to find them.
I need a part number for the P/S pitman arm that will go with my new gearbox.
Welcome to FTE
D2TZ-3590-B .. P/S Pitman Arm-Regular & 1974/79 Super Cabs / ID engineering number cast onto the arm: D2TA-3590-BA / Obsolete
Applications: 1972/79 F100 2WD / 1972/79 F250 2WD under 8,100 lbs. GVWR / 1975/79 F150 2WD.
How hard do you think it will be to find one now?
Old Oct 21, 2012 | 09:47 AM
cayce73f100
Thanks for the help number dummy . Now i can call and speak intelligently while shopping for a pitman arm.
Inline66
WTB - Parts & other
Nov 10, 2016 02:20 PM
THAT.GUY
Apr 10, 2012 04:39 AM
FLN
Jun 10, 2011 07:43 PM
dclary
Feb 4, 2009 04:28 AM
dogguira
Jan 21, 2009 02:32 PM
