Sponsored by: Auxito
Engine miss
Old Oct 16, 2012 | 08:17 PM
bloodypulp's Avatar
bloodypulp
Engine miss
I have a99 5.4 and its missing slightly when cold mostly .can anyone help with cause. I'm thinking egr poss did tune up 7 mos ago so I don't think it's plugs or coil pacs seems to get better when it warms up
Old Oct 16, 2012 | 09:24 PM
QuarryTruck's Avatar
QuarryTruck
See if the truck is trying to give you any codes. Bring her to an auto store like napa,auto zone, advance auto and so on. They will do it for FREE and who knows while you're there you could buy the part you need to fix her
Old Oct 17, 2012 | 09:24 AM
Denbar's Avatar
Denbar
Does the engine stall any on deceleration? Have you checked for vacuum leaks?
Old Oct 17, 2012 | 11:52 AM
bloodypulp's Avatar
bloodypulp
Yes I replaced vac lines and no change and never dies. Misses every 3 or 4 secs at idie and when od kicks in
Old Oct 17, 2012 | 12:20 PM
Denbar's Avatar
Denbar
Have you checked the Idle air control valve?
Old Oct 17, 2012 | 12:22 PM
Denbar's Avatar
Denbar
Do you think it could be the lock down on the torque converter causing the stumble feeling when shifting?
Old Oct 17, 2012 | 01:29 PM
bloodypulp's Avatar
bloodypulp
No it misses in all gears and idle. I think it prob is something with exhaust gets better when hot
Old Oct 17, 2012 | 01:51 PM
Denbar's Avatar
Denbar
I would probably check the IAC or the DPFE sensor, I have seen both cause the problem you are describing. Could possibly be the EGR valve, but I would check the DPFE sensor first.
If it's the IAC or related to the IAC, it will generally run better after the engine heats up.
The best I can remember if it's the DPFE (controls the EGR valve) or EGR valve related, it's the opposite. It runs better cold than when warmed up. It also causes the engine to skip and stumble during acceleration and is pretty non-existent when cruising.
Old Oct 17, 2012 | 02:00 PM
bloodypulp's Avatar
bloodypulp
Yea it's better at speed
Old Oct 17, 2012 | 02:39 PM
khadma's Avatar
khadma
Carpenter Local 745
Mileage?
Check for codes.
Original plugs, wires, coils etc.?
Sensor maybe going out of range.
Old Oct 17, 2012 | 05:41 PM
Bluegrass 7's Avatar
Bluegrass 7
My feeling on this kind of issue is a connector seating problem that is vibration sensitive and may get sleightly better when the temp get higher due to expansion.
Check the crank sensor connector seating.
Good luck.
Old Oct 17, 2012 | 05:52 PM
bloodypulp's Avatar
bloodypulp
Good luck.
Will check thanks
bduke23
Aug 8, 2018 11:05 PM
CoolitKen
Feb 15, 2018 06:56 PM
rel3rd
Modular V8 (4.6L, 5.4L)
Jan 21, 2008 07:42 PM
rel3rd
Oct 26, 2007 08:01 AM
Donzidog
1997 - 2003 F150
Oct 6, 2006 05:52 PM
