differential
Old May 19, 2003 | 03:51 PM
lucky97's Avatar
lucky97
Unhappy differential
i have a '97 2.3 2wd ranger. i was told that the differential fluid is leaking and it needs to be fixed. first of all how can i tell if it is rear differential? Where do i look. My manual does give out a whole lot of clues. please help
Old May 19, 2003 | 04:26 PM
superrangerman2002's Avatar
superrangerman2002
differential
On the rear diff (rear axel), there are only 4 places it could leak minus the vent tubes (more than likely not the problem).
1. where the drive shaft meets the yoke...a 4 way knuckle is between them, the yoke spins on a bearing inside the diff but has a outer oil seal, any "wetness" or dripping would indicate a leak.
2. diff cover seal, most cases not likely un less it had been altered or the cover was removed and not enough RTV was applied..
3 and 4.
Are the axel shaft seals, need to jack the rear end up and remove the brake drums and rims. You may be able to see some oil leakage with out taking tires off by crawling under the truck and looking for wetness on the bottom sides of the brake drums.
If the axel seals are bad you prolly will have to replace the brake shoes as they may be contaminated with oil.
good luck!
Old May 19, 2003 | 04:33 PM
lucky97's Avatar
lucky97
differential
thank you for the reply. are there any other places that a differential can be other than in the rear?
Old May 19, 2003 | 08:05 PM
redranger90's Avatar
redranger90
differential
a 2wd truck only has a rear differential. a 4wd will have one in the front and in the rear.
there is a nice explanation of how differentials work on "how stuff works" they even describe the different kinds and have animated pics if you're looking for information about them.
