Lock Solenoid Bad?
Old May 19, 2003 | 03:41 PM
tadslc's Avatar
tadslc
Lock Solenoid Bad?
I have a 1988 F150 XLT. I think I have a bad lock solenoid but am not sure. Before I spend the $$$ to replace, any quick and easy ways to test the one I think is bad?
Thanks,
Tad
Old May 19, 2003 | 04:16 PM
steve83's Avatar
steve83
Lock Solenoid Bad?
It's actually a motor - not a solenoid. Just put power directly to the 2 pink wires that run to the back of the door under the armrest support. They often get water inside & rust the bearings solid, but you can find them in MANY Ford products in junkyards, and the new style will fit & work, too. Just make sure it has the same length operating rod as yours. They usually go for ~$30 used.
Old May 20, 2003 | 01:54 AM
Dragrazor's Avatar
Dragrazor
Lock Solenoid Bad?
Is there any way to fix them? Both of mine are not working?
Old May 20, 2003 | 08:49 PM
steve83's Avatar
steve83
Lock Solenoid Bad?
No.
Old Aug 3, 2004 | 10:19 AM
Dragrazor's Avatar
Dragrazor
Where do you get a replacement solenoid?
