Kettle Sound
Old Oct 16, 2012 | 11:33 AM
GeneLaw1's Avatar
GeneLaw1
Kettle Sound
Sometime when I am cruising down the road, I can hear a kettle sound. From inside the truck it sounds like its coming from somewhere on the passenger side, but its hard to tell. It has been doing it for almost a year now, hasnt gotten worse or better...but stays relatively the same. Its only every now and then! It can be when I am on the accelerator, or when I let off the accelerator.
Any one know what this could be??
Cheers,
Old Oct 16, 2012 | 11:53 AM
joe blow's Avatar
joe blow
Sounds like the infamous blown head gasket to me
Old Oct 16, 2012 | 12:12 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
Or an EGR cooler, or just a bad cap. Replace the cap, and put a pressure gauge on the degas bottle, or pressure test the EGR cooler.
http://www.phila.gov/fleet/Warranty%...sb09-08-03.pdf
Old Oct 16, 2012 | 12:42 PM
MisterCMK's Avatar
MisterCMK
It could also be a leaking up pipe
Old Oct 16, 2012 | 01:02 PM
GeneLaw1's Avatar
GeneLaw1
I thought about this. But wouldn't there be some other symptoms too along with it? Overheating...puking, etc?
Old Oct 16, 2012 | 01:03 PM
GeneLaw1's Avatar
GeneLaw1
I also get a faint smell of exhaust in the cab from time to time. Is that another symptom of a leaking up pipe?
Old Oct 16, 2012 | 01:21 PM
texastech_diesel
Token Redneck
Soot where it shouldn't be, like on the insulation on the firewall.
Old Oct 16, 2012 | 01:37 PM
MisterCMK's Avatar
MisterCMK
Yes, you should see coolant puking.
Old Oct 16, 2012 | 01:56 PM
Rusty Axlerod's Avatar
Rusty Axlerod
Maybe degas bottle has a crack on backside.
Old Oct 16, 2012 | 03:08 PM
GeneLaw1's Avatar
GeneLaw1
Well thank goodness I am not losing any coolant, lol...
Old Oct 16, 2012 | 03:09 PM
GeneLaw1's Avatar
GeneLaw1
Any good way to check for this? I would imagine it would have to be at a spot where I am not losing coolant...prob too small for the naked eye? Or are you speaking of a larger crack?
Old Oct 16, 2012 | 03:10 PM
GeneLaw1's Avatar
GeneLaw1
Soot doesnt happen to glow under a black light or something does it? I will take a good look lil later in the week.
Old Oct 16, 2012 | 03:25 PM
MisterCMK's Avatar
MisterCMK
My driver side up-pipe was replaced in August 2011 due to a crack. It made a whistling noise like a kettle at times and did not leave any soot on the firewall. It was cracked inside the flex tubing.
MisterCMK's Avatar
MisterCMK
Ford replaced it as the truck was under warranty until May 2012.
Old Oct 16, 2012 | 03:29 PM
GeneLaw1's Avatar
GeneLaw1
Is the up-pipe pretty tough to get to?
