Headlight connections
Old May 19, 2003 | 03:11 PM
johnr1's Avatar
johnr1
Unhappy Headlight connections
We have two expeditions, 1998 and 2002. We have been running the bright white or halogen bulbs in both vehicles. It appears that due to the temprature of the bulbs, the connector becomes hot and is basicaly burned. Is there a harness or some kind of modification that can be made, or should I simply replace the connectors??
Old May 19, 2003 | 04:57 PM
2003EXPY's Avatar
2003EXPY
Go to this site,read it well,then e-mail Mr. Stern and he will tell you what you need to legally get the maximum lighting from your headlights.
http://lighting.mbz.org/
Old May 19, 2003 | 05:03 PM
Rtpjunior's Avatar
Rtpjunior
Your problem is that you are using the wrong wattage. You need to use 55/65watt (low/high beam) bulbs. Using those aftermarket bulbs is cool, just get them in the right wattage. Some brands, like PIAA, make bulbs that are 55/65w, but their light output is like 110w. I've used them for years, and they haven't melted my lights or connectors.
Action4478
22
Oct 6, 2012 08:55 PM
92aeroXLT
Aerostar
Oct 20, 2011 05:35 PM
dierks
1997 - 2003 F150
Jan 11, 2009 03:36 PM
mab6680
Dec 15, 2005 06:08 AM
ddwood55
Jan 3, 2005 07:33 AM
