I've looked here and else where without luck.
97 f250 eclb
Need part numbers for rear drive shaft u joints (preferably spicer life) and the carrier bearing
To all. Spicer are the strongest, and Brute Forece (NEAPCO) are durn good.
Rear Driveshaft U-joint: Spicer 5-178x or "331"
Front Shaft F250: "1204"
Axle Shafts, D50: ETOZ-3249-A, 5-282x, 5-627x.
The 178, 282, and 627 are all 1350 series and interchangeable with each other, except that the 627 is difficult to fit when its pressed into yokes at both ends, as opposed to pressed in on one end an a u-bolt on the other end. It has a thicker mid-section, and _seems_ to be a tad stronger.
