I have a 250 Inline six that ran great this morning, I came home and parked it, then an hour later went back out to start it, and nothing!
Checked the battery it was fine, replaced the starter, solenoid, and voltage regulator. Checked all connections.
Then I went to start it (it didn't turn over) and the positive post started smoking! So, I went to ****** the cable off, and (with the key in my pocket) it tried to start up! BTW, it melted a hole on the side of the positive post! What could cause this???????? If it matters, this is a 76 Maverick not my truck.
Thanks guys.
Okay, first the lights do come on. Second, while I was out there I decided to try to start it again and I have know idea why, but it started up! The only problem is, the starter didn't disengage and it would not shut off with the key! I had to pull the cable.
