MSD woes
Old Oct 14, 2012 | 07:50 PM
LI250's Avatar
LI250
MSD woes
So for the third time an MSD product has left me stranded. Last year it was a 6A box. Then it was a blaster coil and tonight it was a Street Fire ignition box. You think I would have learned my lesson. At least I didn't remove the dura spark stuff so I was able to fix it on the side of the road. Better off just keeping the stock stuff.
Old Oct 28, 2012 | 05:59 PM
wyoming4x4's Avatar
wyoming4x4
sounds like positive voltage issue.
had a issue once similar to this. had a voltage regulator feeding positive voltage back through a ground. was a expensive lesson but lesson was learned. lost 2 MSD 6a boxes and a alternator during the learning curve. I now have since gotten rid of the voltage regulator and run a single wire system off alternator, simplier setup. MSD is good stuff but if your OEM stuff has some issues can be a pain in the AZZ. the voltage regulator has a diode in it and it failed and bad things happened$$$$ 1977 ford 4wd truck.
Old Oct 29, 2012 | 08:19 AM
LI250's Avatar
LI250
You dont say?
I noticed last week that the wiring to the voltage regulator was causing charging issues. Seams one of the wires is bad and when I move it around it goes from 14.5v to 12.5v. I'm investigating a G3 or GM 1 wire conversion but havent made up my mind yet. I'll check it out once this storm blows through.
Thanks for the tip.
Old Oct 29, 2012 | 08:36 PM
wyoming4x4's Avatar
wyoming4x4
keep us updated!
Can never have enough electrical trouble shooting info!
carprojects
Aug 26, 2020 04:27 PM
sere0501
106
Jun 15, 2014 10:56 PM
Onus
Jan 29, 2012 03:36 PM
Links_vette
Mar 30, 2009 12:20 PM
gtspowerstroke
Aug 7, 2005 08:49 PM
