need help with codes
Old Oct 30, 2012 | 11:41 PM
BigAlsPSD's Avatar
BigAlsPSD
Originally Posted by danglin
ok do you think it could be the PCM the truck was acting funny for a while and has done some stupid things at time Im just brain storming now I am about ready to get a new truck lol this problem is about to drive me crazy
Here's the information from the shop manual.
FJ9 DIAGNOSTIC TROUBLE CODE.doc
Old Nov 1, 2012 | 09:12 AM
danglin's Avatar
danglin
Here is the update we ran a couple Buzz tests today and got 1,2,3,4,5,6 high to low side open. And 3,7 bad on the cylinder contribution test. As well as Throttle position and ICP Pressure to high and low.
Old Nov 1, 2012 | 09:36 AM
cps's Avatar
cps
Wow, sounds just like my truck. Still have not found the problem after 3 yrs, LOL, still runs fine. Replaced IDM and UVCHs, replaced connector to drivers side UVCH, omhed harness from IDM and all were within spec except 2, but they were barely out. Gave up as it runs fine although i did not have that DTC repair from the manual(i do now) so when the weather gets better i will have another go at it as i am not going to just throw parts at it untill i can hpoefully nail it down. Maybe you will figured it out before me. Roy
Old Nov 1, 2012 | 09:49 AM
SkySkiJason's Avatar
SkySkiJason
I would check all of the grounds on the engine. You (at least) have 2 big ones from batts to block, one from pass-side head to firewall and one from engine harness to fender well - that I can think of. Make sure the connectors are clean and the paint is removed from ground locations.
Did you replace VC gaskets and UVCH's?
I get all kinds of codes with my Swamp's high voltage/high frequency IDM - but no SES lite and truck runs like a raped ape.
Edogrips
16
Aug 26, 2012 10:57 AM
fishon662
Sep 17, 2011 10:17 PM
H60Driver
Sep 10, 2010 01:06 AM
stoney720
Mar 25, 2010 04:33 PM
richierich4
Jan 29, 2006 10:09 AM
