Help! Who makes these?
Old Oct 15, 2012 | 09:24 PM
fordrealdrive's Avatar
fordrealdrive
Aren't you working on a highboy IIRC? divorced t.c.? If so I don't think that would be an issue.
What your saying though makes since about breakage when using a combo of rubber and poly mounts.
Old Oct 15, 2012 | 09:33 PM
thatK30guy's Avatar
thatK30guy
Yep, HB project here but my main concern with the rubber mount under the tranny is the tailshaft housing possibly cracking or breaking if using poly motor mounts.
I already have all the poly stuff for my '75. Leaf springs and shackles, t-case, body mounts and now soon the WCB mounts. But I'd like to replace the factory rubber tranny mount for poly just so everything is up to par and to be on the safe side of not breaking the tailshaft housing.
Old Oct 15, 2012 | 09:35 PM
thatK30guy's Avatar
thatK30guy
I would also like to replace the factory rubber mount on the '79 F250 Supercab 4x4 I'm picking up Wed.
While this truck has the 400/C6/203 setup, I'm planning on tossing the 400 and 203 to replace with a 460 and 205. I know this whole setup is married so I'm aware the tranny mount is different than the HB mount.
Old Oct 15, 2012 | 09:55 PM
fordrealdrive
To my knowledge all Fords trucks of the '70's, whether it be a C6 or a 4spd, 2wd or 4wd, all used the same trans mount.
I don't believe there is a Ford poly trans mount available but I could be wrong on that...wouldn't be the first time!
Old Oct 15, 2012 | 10:20 PM
lafermedavid's Avatar
lafermedavid
WCB
The other day Grinner mentioned he used l&l mounts because thats what L&l told him for clearence issues with his headers,(right location) when he mentioned that I wondered how it would be with WCB mounts and clearence issues.with L&L headers (chassie exit) tolerance?
Old Oct 16, 2012 | 05:50 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
I'll let you know when I get that far, that is my plan too (L&L chassis exit headers & WCB mounts).
Here is another option, I have no word on their quality??
http://performanceunlimited.com/cust...ginemount.html
Old Oct 16, 2012 | 11:13 PM
lafermedavid
Workaholic
thankyou please do.
Old Oct 18, 2012 | 07:46 PM
BDawg171's Avatar
BDawg171
Engine mounts arrived today. Not bad for coast to coast. They actually came USPS, unlike UPS Ground like they said. Shipping was $10.48 per the label. I guess they like to pocket the $5+ as "handling" ???
They are for the most part like the photos in the first post. Certainly heavy-duty.
They are missing the washer(s) for the frame mounting perch stud/nut however. Also, the weld on one of the mounts isn't as consistent as the other, but only in one spot. The half-moon welds you see on the outside of both mounts look very good. On the backside though, on the one, they just weren't as smooth with one of the beads. No doubt it will hold up.
I know you want pics, but you'll have to wait until tomorrow...
Old Oct 20, 2012 | 06:35 AM
miottimouse's Avatar
miottimouse
i used those mounts on my 79 460 bronco conversion at $160 for the kit they were not cheap but fit well i am running stock 460 hp so i dont know how they would do with more hp/tork on my 78 reg cab with the 501 stroker in it i broke the stock ford mount with in a week i now have 2 chain/turn buckles 1 on the bell houseing bolt 1 on the front head that held every thing in place
ROBBINthaHOOD
Oct 4, 2016 03:50 PM
ROBBINthaHOOD
Jun 16, 2013 03:19 PM
ROBBINthaHOOD
Sep 19, 2012 03:42 AM
