rear gears
Old Sep 4, 2002 | 08:12 PM
92lightning's Avatar
92lightning
rear gears
I thought I could tell my rear gear ratios off the tag on my trucks rear end. I read them as S837B L55 88 2B24.I don't have a clue as to what they mean.Could someone please decode this for me. thanks sav
Old Sep 5, 2002 | 08:53 PM
markus's Avatar
markus
rear gears
I think the L55 means it is a Limited Slip 3.55. What is the axle code is the drivers door jam?
Old Sep 5, 2002 | 09:46 PM
92lightning
rear gears
The door stiker has H9 as the code. I don't know if it's right,I do know the motor/tran have been changed to a first gen.Lightning.I wouldlike to find the numbers on the motor. Any diretions on finding them would be appreciated. Thanks Scott
Old Sep 5, 2002 | 10:59 PM
optikal illushun's Avatar
optikal illushun
rear gears
heres ur decoded axle tag (as according to my chiltons)
8.8" rear
3.55 gears
limited slip
2wd
Old Sep 6, 2002 | 06:51 PM
MustangGT221's Avatar
MustangGT221
rear gears
Yes, that "L55" is suppose to be 3L55, you have 3.55 gears and a Limited slip, great setup if that is still what's in there, probably is. If you think the gears have been changed, I can tell you how to do that, but I won't type it if i don't have to.
Primary rig is Green Thunder:
95' F-150 XLT 4x4, 302, 5 spd, MSD 6A, Flowmaster American Thunder Exhaust, Sunroof, Clear corners w/ Diamond headlights, CD player with 2 10" subs and some 32" BFG Muds .
That's it for mods now, saving for a Stang. Check out my Gallery for a look-see.
Old Sep 6, 2002 | 10:21 PM
optikal illushun
rear gears
i have a 3.55 limited slip in the rear. is there a way to tell if i have a limited slip (posi) in the front? my dad has it, but he ordered it in his 95
Old Sep 7, 2002 | 10:47 AM
MustangGT221
rear gears
There is a sticker on the passanger side of the axle. That will tell you. Or, you can lift the tires off the ground, lock the hubs, and turn 1 tire by hand. If the other tire spins in the same direction, it's LS, if it turns in the opposite direction, it's open. I highly doubt it's an LS front, those are VERY rare.
Old Sep 7, 2002 | 02:07 PM
dave186's Avatar
dave186
rear gears
Mick1930
Sep 6, 2009 08:13 AM
TN615
Jan 17, 2009 07:34 AM
blloyd
36
Nov 29, 2007 12:05 PM
Fords&Farmalls
Aug 20, 2007 03:28 PM
JBL
2004 - 2008 F150
Jan 7, 2005 05:32 AM
