6.2L V8 Discuss the 6.2L V8
Running wires under carpet? 2012 F 250
Old 10-21-2012, 12:03 PM
Dave HM's Avatar
Dave HM
Dave HM is offline
I want to run a couple of wires from the Upfitter Switches to the left front underside of the bed. I understand that there are rubber plugs in the front and rear of the lower corners of the crew cab.
I would like to run the wires along the side under the carpet from front to rear. So how does one remove the inside moldings to be able to get wires under the carpet?
Hopefuly someone here has conquered that challenge and is willing to share.
I think the alternative would be to find the plug in the right front corner and run the wires exposed under the cab if necessary.
thanx
Old 10-21-2012, 02:39 PM
Dave HM's Avatar
Dave HM
Dave HM is offline
guy I knew showed me how to yank straight up and they pop off.
was able to fish the wires through the rest of the paneled areas and out the rubber plug in the back.
Old 10-22-2012, 02:10 PM
2000silverbullet's Avatar
2000silverbullet
2000silverbullet is offline
Post back up if you have any other questions about running wires. I still have a pretty good idea of all the nooks and cranny's you can get wire into from my stereo project.
Old 10-30-2012, 08:24 PM
Adventure Rider's Avatar
Adventure Rider
Adventure Rider is offline
I don't know if you are planning to do this but it is good practice to run along other wire harnesses to keep clean and neat and at the point of exit from the cab it would be good to encase the wires to prevent chaffing
CO Wapiti
2017+ Super Duty
60
03-13-2023 08:25 PM
Meridian_Mike
27
01-21-2019 07:03 AM
T.Mainus
1999 to 2016 Super Duty
02-21-2010 10:20 PM
ptesmoke
1983 - 2012 Ranger & B-Series
08-23-2008 02:23 PM
Moose F150 4x4
12-31-2004 11:56 AM
Quick Reply: Running wires under carpet? 2012 F 250
