Stripped Intake Manifold Bolt Help!!!
Old Oct 13, 2012 | 10:04 AM
rebel33382's Avatar
rebel33382
Folks, was torquing the intake manifold bolts this AM(after gasket replacement) and the bolt(first one) on the driver side stripped out at 25 ft/lb's. I tried another bolt and it does not want to torque down. I am a little scared/aggravated right now. Please tell me there is a fix at this point without tearing everything back down!
Thanks in Advance.
Old Oct 13, 2012 | 10:11 AM
bertha66's Avatar
bertha66
Did the bolt strp or the bolt hole? If the bolt striped, clean out the holes and replace the bolts. If the hole striped, a Heli coil maybe the answer. But I would run a bottom tap down all the other bolt holes before putting in a bolt.
Old Oct 13, 2012 | 10:20 AM
rebel33382's Avatar
rebel33382
the head threads are stripped...
Old Oct 13, 2012 | 10:25 AM
Fordfleettech12's Avatar
Fordfleettech12
I agree with this. Step back, take a breath...thread repair is a slow gentle process. Go to the AutoParts store and get a helicoil kit. Not fun but your other option is tow it to a garage that will do the same repair.
Old Oct 13, 2012 | 01:36 PM
rebel33382's Avatar
rebel33382
I got an 1/2 longer bolt to see if there were some better threads further down, and there were! Just put 2 washers on and torqued down!!! just took truck for a road test NO LEAKS!! Will these 352 idle like butter? I have tried to get mine smooth but the gear shifter always has a slight shale to it..?
Old Oct 14, 2012 | 11:23 PM
airharley's Avatar
airharley
After the first full heating cycle you need to re-torque all the intake manifold hardware to make sure you don't have seal leaks.
bl2009
3.8 & 4.2L V6
Nov 9, 2016 09:29 PM
arctic_driver
Mar 22, 2015 04:38 PM
flipklos
Jan 2, 2009 02:07 AM
hatcatz
Nov 20, 2005 08:54 PM
ejpreston
1983 - 2012 Ranger & B-Series
Apr 6, 2004 05:33 PM
