t-case question
Old May 19, 2003 | 09:35 AM
pingaling's Avatar
pingaling
t-case question
can I put a borg warner 1350 on a c-4 transmission?
do the spline counts and bolt patterns work?
Old May 19, 2003 | 06:16 PM
steve83's Avatar
steve83
t-case question
Where are you getting a 1350? I've never even seen that number. '85-96 F-Series use either the 1356 or the 1345.
http://www.truckpulls.com/Transferca...mage_Index.htm
Old May 19, 2003 | 08:07 PM
Ken aka Savage's Avatar
Ken aka Savage
Thumbs up t-case question
Yo Steve83; Thanks for the link, I saved that one into my favorites. I noticed in the link you provided that it did list the 1350 but that it's off the Ford mini truck applications.
Enjoy'n the site, lots of good info to glean & hang on to for future reference.
Old May 19, 2003 | 08:13 PM
Ken aka Savage
t-case question
Yo Pingaling; Check out Advance Adapters here
Old May 19, 2003 | 09:54 PM
Ken aka Savage
t-case question
I did a little follow up, but Advance Adapters doesn't list a kit to do what you started to ask about, the do addapt the C4 to the following T/C's...
Dana 18 6spline
Dana 20 6 spline
Dana 300 23 spline
and several chain drive New Process transfercases.
What are you putting this into? What size of motor, stock or hopped up?
In my opinion, depending on what you are trying to accomplish, I avoid "chain drive" transfercases as much as possible because they never stand up to hardcore use as well as a gear drive transfercase. If you wanted the ultimate low range gearing behind your automatic, addapt your C4 to the Dana 300, [2.62:1 low range] then swap in a Tera Low Manufacturing 4:1 gearset & if necessary clock the T/C to the left side output... . Lots of work but like I said, it depends what you are trying to do with it.
Old May 19, 2003 | 10:20 PM
steve83's Avatar
steve83
t-case question
I've towed ~12,000lb, ripped out stumps, and driven everywhere I've ever wanted to on my original NP-208. In fact, it's probably the ONLY part on my truck that has never been serviced, repaired, or replaced. I know everybody dogs on chain-drive t-cases, but I can't kill this one no matter what I do. I've even towed a loaded trailer in front-wheel drive when my rear axle went out.
Old May 20, 2003 | 09:33 AM
pingaling's Avatar
pingaling
t-case question
thanks for the advance adapters link...
I'll give you guys some more info.
I'm putting a 351w infront of a c4...I have the 1350 off the truck its going into..(lifted 88 ranger, a tight swap even with the body lift)
I have all the parts to go 2 wd...but I dont wanna lose my 4x4.
I'm on a budget (college kid) so I was wondering if I had to swap out my t-case.$$
I think I can do it with that adapter...anything else I should know doing this swap?
any help is much appreciated.
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
