6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Best tuner/DPF delete kit?
Old Oct 11, 2012 | 06:12 PM
tuffnufly81's Avatar
tuffnufly81
Hello,
My extended warranty is about to run out and I was wondering what the best tuner/DPF delete kit is out there today? I'm also going to remove the EGR coolers.
Old Oct 12, 2012 | 06:32 AM
Greyman's Avatar
Greyman
The H & S line of tuners is the best, I have the mini maxx and love it.
Old Oct 12, 2012 | 10:43 AM
bigjr2's Avatar
bigjr2
Ok so where do you find the tuners and everything you need to do it?
Old Oct 12, 2012 | 11:26 AM
89hawkgt's Avatar
89hawkgt
Lots of online dealers but I just found a local diesel shop, good for your local economy and was even $25 cheaper than most online sites. Mini maxx installed last night, no dpf delete yet, that's this weekend, already noticed a big power difference. It's intoxicating!
Old Oct 12, 2012 | 11:46 AM
bigjr2's Avatar
bigjr2
Ok maybe this is a dumb question but do you have to have a tuner to do the DPF delete? and im not looking for horse power got plenty of that just maybe better fule and less crap to go wrong where do I start?
Old Oct 12, 2012 | 12:09 PM
89hawkgt's Avatar
89hawkgt
Tuners are a must if doing the delete, truck won't run without one.
Old Oct 13, 2012 | 08:52 AM
RM2738's Avatar
RM2738
There's a product called DPF-R that ONLY eliminates the regeneration process and allows you to remove the DPF.
Old Oct 13, 2012 | 10:05 AM
bigjr2's Avatar
bigjr2
So if the dpf is gone what about the egr should it be gotten rid of as well?
Old Oct 13, 2012 | 10:10 AM
tuffnufly81
I will be removing the EGR's for reliability because there have been cases where the coolers start leaking and pushing coolant into the motor. The coolers are nothing but heat exchangers and over time will break down.
Old Oct 15, 2012 | 01:54 PM
jasfaa's Avatar
jasfaa
Get a tuner. Even if you just want to remove the DPF only its nice to watch your temps for towing or just general driving around. I like to know that the EGT's are below 350 before I shut off my truck and most tuners have this as a selectable item. the DPF-r I dont think does anything more than trick your computer.
Old Oct 15, 2012 | 03:03 PM
bigjr2's Avatar
bigjr2
I think ive decided on this set up H&S Mini Maxx, Diamond Eye DPF/Cat delete, and an S&B intake kit
Old Oct 15, 2012 | 04:44 PM
jasfaa's Avatar
jasfaa
Its a good setup. I have everything there except your intake and it works well. I bought the downpipe too but havent put it on yet. Just havent had the time. The delete is simple. the tuner is simple too.
Old Oct 15, 2012 | 04:51 PM
bigjr2's Avatar
bigjr2
Boy I sure hope its simple coz they sure look and sound complicated LOL I asked if it came with a tuning for dummies book the guy had no sense of humor
Old Oct 16, 2012 | 02:17 PM
xpl0sive's Avatar
xpl0sive
i've got the mini maxx i picked up off craigslist for $400. works great. i've also go the diamond eye cat/dpf delete kit sitting in my garage that I'm waiting to install. i'm gonna keep the stock air intake system for now and see if i pop any filter minder messages. I think it should be OK as my goal is not to get more HP out of the truck, but to improve fuel mileage, so I'd be driving around at no power/mild most of the time
Old Oct 16, 2012 | 02:28 PM
jasfaa's Avatar
jasfaa
I forgot to mention that I had to get a new exhaust clamp when I did my delete. The kit did not come with one or it was lost in transit. Make sure you have one prior to taking your dpf/cat off as a new one was needed on the cat end since it is welded to the pipe.
