2011 6.7 died
Old Oct 10, 2012 | 09:44 PM
gregtx52's Avatar
gregtx52
2011 6.7 died
i have a 2011 6.7, bought new about a yr. ago. 18k on it. never a problem. driving to austin today, the engine light came on, running normal. "pull over safely" light came on, with an alarm, and within 1/8 or a mile, died, windows worked, lights worked, radio, etc........ but motor dead....... called dealer service dept (was still during bus. hrs), and he sounded like he knew exactly what it was. a sensor, saying it was running to hot, and shut down to save the engine. he even said, "probably just a bad sensor", no real problem...... shut down that quick ? crazy...... anyway, towed to covert (roadside asst paying for itself) and we will see if it's simple as a sensor, or fuel system.... I'll let everyone know what it is........
Old Oct 10, 2012 | 09:53 PM
ruschejj's Avatar
ruschejj
I tell you from experience. If the engine blew you would know it.
Sensors are pretty common. If there are stored codes it looks good for you.
Old Oct 10, 2012 | 09:59 PM
Tom's Avatar
Tom
Hi Greg, welcome to FTE!
I'm splitting your post off into its own separate thread in the 6.7L forum. That way it's easier for us to discuss your issue and not get it confused with Joel's problem.
Old Oct 10, 2012 | 10:10 PM
KC8QVO's Avatar
KC8QVO
Greg,
Sorry to hear of the problems. Welcome to the group. I am sure you have been around for a little while reading threads. There is a lot of knowledgeable people here.
Old Oct 11, 2012 | 05:02 AM
senix's Avatar
senix
On the 6.4 you can bypass that issue if you know for sure that is the cause. But you better have a scanner to check.
Could that be done here too?
Old Oct 11, 2012 | 05:49 AM
ruschejj's Avatar
ruschejj
How did you guys figure that out? We need more info from ya Scott. Tell us what to do and why it works, then maybe one of the fine folks like cheezit or vloney can tell us something.
Old Oct 11, 2012 | 07:27 AM
CascadeF250's Avatar
CascadeF250
Sorry for your problems and welcome to the forum. Let us know the outcome .
Old Oct 11, 2012 | 07:32 AM
senix's Avatar
senix
there is a jumper off the passenger side battery that you can use. I don't have the stuff with me right now but if I recall use just jump the battery with that to start it.
Old Oct 11, 2012 | 07:44 AM
darren32's Avatar
darren32
That does sound very similar to a couple of other sensor issues. I do believe that it is one of the temperature sensors in the exhaust that was the culprit in the cases I read.
I do not recall anyone getting "pull over safely" from an engine, fuel system or even a turbo failure. Not that I have ever read about anyway.
Here is one of the threads but there are a couple similar on here.
https://www.ford-trucks.com/forums/1...afely-now.html
Old Oct 11, 2012 | 11:16 AM
tolliewolly's Avatar
tolliewolly
sorry to hear. Keep us posted.
Old Oct 11, 2012 | 11:41 AM
riverrat41's Avatar
riverrat41
Did they take it to Colvert in Hutto?If so,when you go up there look up a tech named Heston Lowry.He is my son and tell him to get it fixed for ya.He works on all diesels there.
Old Oct 11, 2012 | 12:01 PM
The Hoot's Avatar
The Hoot
Sorry for your troubles Greg. Let us know what they find.
Old Oct 11, 2012 | 12:19 PM
Javi1's Avatar
Javi1
Cool... I'll look him up when I go in for the 5000 mile check up
Old Oct 11, 2012 | 01:22 PM
gascan's Avatar
gascan
Covert Ford in North Austin (right on US 183) has a great service department.
Old Oct 11, 2012 | 04:59 PM
4stroke's Avatar
4stroke
Welcome to the forum Greg. Sorry to hear about your trouble, hopefully it will be an easy fix and you will be back on the road in no time.
