Coolant leak
Old Oct 9, 2012 | 09:42 PM
dlibson's Avatar
dlibson
Yep, the heater hose clamps to the plastic "y". Then one end at the motor, other at the degas.
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
Just turn the picture over for correct direction of fit.
Connect big end to motor, the other end connects to degas and heater hose, wal lah, fixed.
Old Oct 9, 2012 | 09:43 PM
amdriven2liv
If it wasn't dark yet, I would run out and take a vid.
Old Oct 9, 2012 | 09:45 PM
dlibson's Avatar
dlibson
Originally Posted by GeneLaw1
Is that the big black cylindrical pipe? How do you move that? I have never taken it off.
Any suggestions on the tool?
Yes, the big black tube. You need a deep 11MM socket to loosen the boots at either end.
The best tool for the clamp is the one made for them. It's a cable that will hook on the clamp that you can squeeze to lock. Work great, but spendy for a one time use.
Old Oct 9, 2012 | 09:46 PM
dlibson's Avatar
dlibson
Otherwise a good long handled pliers.
Old Oct 10, 2012 | 08:57 AM
GeneLaw1's Avatar
GeneLaw1
Thank you all for all the responses and help. I looked up that part...$60! Def the most expensive hose replacement I've ever done, lol. I will report back once I get started, seems straighforward enough. I am just worried about getting that clamp off near the engine.
Old Oct 10, 2012 | 08:58 AM
GeneLaw1's Avatar
GeneLaw1
If you have an opportunity, I would love to see that vid!
Old Oct 10, 2012 | 05:01 PM
GeneLaw1's Avatar
GeneLaw1
So I loosened up the strap clamp aroudn the big black tube and it wont budge. And I supposed to loosen the bolts holding on the base as well and remove that too?? Asking before I do it because I do not know what any of that is...
Old Oct 10, 2012 | 05:39 PM
GeneLaw1's Avatar
GeneLaw1
OK so I think I can get this thing done if I just could remove that pipe. It looks like there is another strap clamp at the other end, but it seems impossible to get a ratchet down there! Even with the longest socket extention I have....do I need to get an even longer one??
Old Oct 11, 2012 | 06:25 AM
dlibson's Avatar
dlibson
You don't want to remove that if you don't need to. Then you have to clean all the surfaces up well and re-gasket it.
Try twisting the hose back and forth and pulling at the same time. Are you sure you got the clamp off enough?
Old Oct 11, 2012 | 08:59 AM
GeneLaw1's Avatar
GeneLaw1
Yes I have loosened the clamp all the way! I didnt realize this would cause me to have to re-gasket it, luckily I have not removed it.
Also, did you remove the clamp from the bottom of the tube as well, and take the tube completely out?
Old Oct 16, 2012 | 02:23 PM
dlibson's Avatar
dlibson
Sorry, yes I did.
Old Oct 16, 2012 | 02:49 PM
  #28
GeneLaw1's Avatar
GeneLaw1
Sorry, yes I did.
No problem! I actually got pretty frustrated with the whole thing and took it to my mechanic to get it done. I watched him do it...it was poetry in motion. He got that tube off with no issue what so ever, lol.
Old Oct 16, 2012 | 03:20 PM
  #29
BPofMD's Avatar
BPofMD
Veteran: Navy
That's because YOU loosened it!! LOL
Old Oct 16, 2012 | 03:24 PM
  #30
GeneLaw1's Avatar
GeneLaw1
You are probably right, I wiggled that thing around a good while! But I called myself tightening it back up so I could move the truck, but I am sure I did not get it that tight. Plus he was using a nice drill....I was using a ratchet/socket, ha!
