need help
Old Oct 9, 2012 | 05:54 PM
wiyakpa's Avatar
wiyakpa
need help
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--> Ok guys need a little help I have a 95 f-250 and started having a fuel leak about a month ago. I emptied the fuel filter bowl did not find any cracks put it all back together and no leak. Yesterday it started again its coming out where the lever goes into the filter bowl for water drain is there a serviceable o-ring and if so how does that shaft come out?
<!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]-->
Old Oct 9, 2012 | 06:29 PM
Red97350's Avatar
Red97350
I think there are 2 o-rings for the lever, but I don't know if the lever itself will come out. I got an o-ring kit and did all the o-rings in the fuel bowl at once.
Red
Old Oct 9, 2012 | 07:00 PM
fordpride's Avatar
fordpride
Here ya go
http://www.dieselorings.com/docs/FuelDrain.pdf
Old Oct 9, 2012 | 07:31 PM
wiyakpa's Avatar
wiyakpa
thanks guys Ill give it a go
Eddie06f350Harley
Dec 4, 2013 06:21 PM
szotty
17
Dec 11, 2011 01:56 AM
Ba24dupont
Nov 27, 2010 07:02 PM
99350Ron
Jan 25, 2010 02:28 PM
SC_Dave
Feb 24, 2008 07:46 PM
