Sponsored by: Real Truck
New Batteries Installed.
Old Oct 9, 2012 | 10:25 AM
xaviar's Avatar
xaviar
Hi all. Last weeks temp was 32 @ 5am. Got into my truck, turned the key and had that slow crank at first and fired up only to make a ton of racket and run rough. Cleared up in about 5 minutes and ran fine. A few days later. Temp 44 @ 4:45am. Hooked up my Scangauge II. Volts to FICM 13.8. KOEO 46-48 Volts. KOER 46 Volts at start to 48 then 47.5 to 48.
Checked charging system. 13.4-13.8 while driving. Passenger side battery 10.2 Driver side 11.8. Decided its's time for batteries. Ended up picking up 2 batteries @ local parts store. 1035 CCA @ 32. 875 CCA @ 0. These are East Penn batteries made in the USA. Good write up so I bought them.
All I can say is, WOW, what a difference! First notice upon startup. Truck ran quiet! I mean you couldn't hardly hear the truck run and no injector knock.
I'm thinking with those low batteries it was effecting FICM and how my injectors were operating.
Upon driving. Truck even drives and shifts different. Throttle response seems better. Maybe it's just me. But, overall truck is performing very well since the new batteries.
Has any one else noticed these type of changes after installing new batteries?
Charging system checked out @ 13.9 while running. Passenger side 13.9 volts. Drivers side 13.9 volts. A big difference from when I checked last week!
A good idea would be not to wait when battery issues start appearing as some have stated here.
Thanks for this forum and others like it.
kevinb63
2009 - 2014 F150
Apr 29, 2017 08:50 PM
Moby Dick
Oct 14, 2013 02:35 PM
cleatus12r
Jan 5, 2008 01:37 PM
Rio_Grande
Nov 6, 2007 09:03 PM
brownieboy525
21
Oct 22, 2006 08:25 AM
