1996 ford f250 diesel
10-08-2012, 11:33 AM
on
what im wondering is does a 4.10 gear work with any other gear
10-08-2012, 12:01 PM
Huh?
Can you restate that in the form of a question?
Richard
10-08-2012, 12:21 PM
Quote:
Originally Posted by
DarkStarMedia
Huh?
Richard
Are you asking what happens if you have 4:10 in on axle and 3:55 in the other? or so? If so it doesnt work, they have to have the same axle relation.
10-08-2012, 12:32 PM
Yeah, you have to have the same axle ratios front and back. If you can get the rear axle too, just change them both!
10-08-2012, 12:43 PM
on
thanks? yeah i had someone ask me and i didnt know if it was possible
10-08-2012, 12:49 PM
It would work but you would not be able to use 4WD... making it useless...
So as the others indicated... No with an asterisk...
Richard
10-08-2012, 07:19 PM
Just think it through -- what would happen if you drove the front and rear axles at different rates?
10-08-2012, 07:39 PM
I have seen guys do it but the tire heights were drastically different and between ratio and tire height they were matched...but we aint sand draggin here.
10-08-2012, 09:04 PM
You can do it. But it's a horrible idea and will not function very well, if at all.
dans 51 f2
03-17-2010 03:44 PM
speedracer54729
06-05-2008 08:57 AM
DNewton
10-20-2006 09:10 PM
4030eddie
02-02-2006 04:38 AM
Nor Cal ford
08-01-2003 01:25 PM
