gear question?
Old Jun 4, 2008 | 09:03 PM
speedracer54729's Avatar
speedracer54729
gear question?
i have a 85 f-250 with straight axels not sure if it was factory i boughyt a 84 f-250 diesel frame with IFS will the gears from the ifs axel fit in my straight axel??
Old Jun 5, 2008 | 08:42 AM
Sycostang67's Avatar
Sycostang67
Not likely. The straight front axle is probably a D60 and the biggest IFS front axle was a D50 which uses a ring gear similar to a D44. The 85 may also have a sterling 10.25 rear where as the 84 may have a D60 rear.
Old Jun 5, 2008 | 08:57 AM
uncle.stosh's Avatar
uncle.stosh
If they are both D44's then yes they can be interchanged.
TTB and straight axle D44's use the same R/P except if it's a High Pinion D44 straight axle. They are different.
