icp climbs to 2100 psi
idm relay good and working
no codes
oil level good
resevoir full
full pump working
good fuel
cranks stumbles and smokes.
Please Help
does it blow out huge clouds of white smoke when ure cranking it? if so try a buzz test on the injectors. i had that same problem and it was bad injectors that wouldnt let it fire.
would just crank and blow white smoke
Also here is the location of the IDM, inside the inner fender directly behind the F-X50 badge, obviously you do not have to remove the fender to get to it.
no prob bud. best of luck. but like he said the harness for the injectors could also be loose. fyi the wireing harness for the injector / g.ps is also the valve cover gasket. but the buzz test will indicate broken/ disconnected wires
