38 vs. 38r - physical differences ?
Old Oct 6, 2012 | 09:34 AM
Christof13T's Avatar
Christof13T
Ok. So since i have this old thing... and if im going to rebuild it... why not upgrade it?
From what i understand, the major difference between the two are the bearings.
38 uses an oil bushing
38r uses ball bearings...
Why couldnt one just find bearings of the measurements required and retro fit on a 38 to convert it?
Couple that with an ats style housing for the compressor?
Are there other differences that i am missing?
Xtof
Old Oct 6, 2012 | 10:46 AM
timmyboy76's Avatar
timmyboy76
lol, thought the same Chris, thought the same. I used to work in the dental industry, which a few of my buddys' still do. The companys' a subsidiary of TIMKEN I have the bushings from a previous rebuild, and with you mentioning it, i'm gonna bring them with me today and drop them off.
They use 2-styles in the industry. Angular and radial. I would think, these would need radial..(ballbearings fixed within the cage), also, theres 2-models....slowspeed bearings and high speed bearings. What we'll need to know is at what rpms' the turbo is able to reach, in order to know what type bearing to install, PLUS the bearings will ned to be a shieldless bearing, for oil to transfer/move throughout them.....
Old Oct 6, 2012 | 11:30 AM
Tugly's Avatar
Tugly
Does this help?
Old Oct 6, 2012 | 02:46 PM
429 f-100's Avatar
429 f-100
here is a early 99 and a 38r
Old Oct 6, 2012 | 04:16 PM
SkySkiJason's Avatar
SkySkiJason
Its more than that I'm afraid. Ported housing and different wheels make the 38R capable of moving something like 30% more air than stock charger. The 38R is not user rebuildable - aka disposable. It is also LOUD as hell and frankly more annoying than I can stand. This is not the turbo I would choose again...
If you are ready to get away from stock, my recommendation would be a T4 set-up and S366 (or bigger if you go with bigger injectors). A complete T4 system and S366 is about the same price as Int'l bellowed up-pipes and a 38R. Also, future upgrades are literally unlimited!!!
Old Oct 6, 2012 | 10:25 PM
Tugly's Avatar
Tugly
My experience with the 38 vs. 38R (so far). With the AIS, the 38 would whistle out the passenger window as long as the window was down and there was something to bounce the sound back - like in city streets. One time I drove next to a bus with its flat sides and got on it - the trubo let out a harpy's battle scream. Now I can just hear the 38R when I get on it, but not out the passenger window - the sound sneaks around to the driver's side (faintly). The 38 sounded more like a musical instrument with a bit of a warble. The 38R sounds like a jetliner engine whine on spool-up... I spent enough time around planes to recognize the nuance. If it's loud, my AIS and Lariat interior masks it pretty well and only the poor ricer to my right gets the brunt of it.
Old Oct 7, 2012 | 08:11 AM
SkySkiJason
Oh it was quite tolerable with AIS in front of it, but I could suck the filter minder into the red at will, even with fender-sleeve mod. Meanwhile, I was sucking oil out of the engine thru CCV. This was a FAIL for my application, and I 'only' had 160cc AC codes...
Old Oct 7, 2012 | 10:32 AM
Tugly's Avatar
Tugly
Very good point. I need to check my filter minder. Your sig still shows the AIS... any changes?
Old Oct 7, 2012 | 11:26 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Tell me this ain't purdy.
Old Oct 7, 2012 | 04:06 PM
SkySkiJason
The AIS was X with stock injctrs and van turbo and was no problem. When the X engine broke, I decided to put AIS in F350 instead of 6637. After using 1.5 to 2 gals of oil every 4k miles, I decided it was sucking oil out of ccv. Back to 6637 and no abnormal oil consumption...
Old Oct 7, 2012 | 05:47 PM
Robert6401's Avatar
Robert6401
So really guys, 38r with AIS, is it more tolerable? How does it compare to a stock with wicked wheel?
Old Oct 8, 2012 | 09:27 AM
SkySkiJason
I never had a WW, but the AIS made 38R almost stock-quiet. There was a louder whistle at high boost, but the constant, absolutely intolerably ridiculous, never-ending vacuum cleaner sucking/whistle sound was almost gone. The 38R goes from a LOUD sucking noise at 5psi to a LOUD high-pitched whistle at 30psi. With a wall on the right side of the truck and no muffler, it makes a cat-in-a-blender noise at high boost that must be well over 100db in the truck with windows down. This happens A LOT when towing heavy through the cuts in the mountains of GA, NC, TN and 'out west'.
If ya can't tell, I don't care for this turbo with a 6637 in front of it. When I read posts where people delete the foil on CAC pipe, etc to make their turbo LOUDER - I have to think they don't spend 10, 12 or 16hrs a day driving their trucks. I ain't no 'old guy' (yet...) - but I am fully aware of how reducing noise in the cab in ANY way will reduce fatigue while driving. To me, less fatigue is a safety feature - besides allowing me to go further in a day..........
Old Oct 8, 2012 | 10:07 AM
CSIPSD's Avatar
CSIPSD
FYI...
THe turbo can reach speeds of 30k RPM... Normal is around 20k...
And I agree with above post. However with the 1.15 housing it does quite the 38R somewhat.
Old Oct 8, 2012 | 10:14 AM
stinson 108-1's Avatar
stinson 108-1
stinson 108-1
I agree with Jackson about fatique. You can see in my sig what I run. I did some sound deadening years back with dynomat and carpet padding. I also did some on the firewall and the intake tube and lined the inside of the air box. You can hear mine going through the gears, but then dies down at cruise to where you don"t even notice it. Under load it spools up to where only dogs can hear it. So with a little extra work it is quite acceptable, and the mat/pad reduces road noise. I drove from N.J. to RRE and my wife never commented once about it. It also seems to be a lower tone than the WW.
Old Oct 8, 2012 | 10:49 AM
Robert6401's Avatar
Robert6401
Great info guys. I am still trying to decide if I would be happiest with a van turbo and the extra cash for other stuff, or a 38r and broke.
