Sponsored by: Real Truck
Front Trailer Hitch
Old Oct 8, 2012 | 05:19 PM
CTYankee46's Avatar
CTYankee46
Front Trailer Hitch
I just bought a 2005 F250 SD V10 with the fog lights that are fairly close together in the front bumper opening. I need to put a front hitch on but my hitch shop told me the fog lights must be removed. Is there anyone that knows if they can be renstalled in the opening or elsewhere. Is the hitch shop correct?
Thanks
Old Oct 8, 2012 | 05:32 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Most front receiver hitches do require the removal of the fog lights. WARN's model allows you to keep the fog lights but the hitch is $300, roughly twice that of other hitches. IMO get the $150 standard hitch, and spend the other $150 on better fog lights.
Old Oct 8, 2012 | 05:34 PM
spongecop's Avatar
spongecop
Semper Fi
Anyone have a link on the best front hitch
Old Oct 8, 2012 | 05:38 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
On paper, all the ones I have seen are the same, rated at 9,000lbs line pull.
Old Oct 8, 2012 | 05:59 PM
redford's Avatar
redford
FTE Leadership Emeritus
It sort of doesn't matter. The BEST hitch isn't going to do any better than the worst hitch. You only use the front hitch to maneuver and park the trailer, so "performance" doesn't mean much, as long as it doesn't fall off or move.
Old Oct 8, 2012 | 06:04 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Thats assuming youre using it to park a trailer. What if you're like me and use it for a winch?
Old Oct 8, 2012 | 06:07 PM
redford's Avatar
redford
A slow or static 9000 pound load on a winch is far different than towing a 9000 pound load at 65 MPH.
Like I said, just get one that doesn't move under load.
Old Oct 8, 2012 | 07:11 PM
CTYankee46's Avatar
CTYankee46
Thanks for the reply. I am new to this Truck game. Where would you mount the Fog Lights if they are moved from the Factory location? I can't mount them on top of the cab as the truck wouldn't fit in the garage.
Old Oct 8, 2012 | 07:29 PM
pbeering's Avatar
pbeering
This is my approach:
Weld a tab onto a std receiver tube and you are good to go. I have used this for self recovery and recovery of others on several of the fleet. No impact on driving lights.
Old Oct 8, 2012 | 08:21 PM
BobbyDiesel71's Avatar
BobbyDiesel71
draw-tite make an excellent front receiver hitch. I have it installed it on mine.
I will tell you that it will block airflow to the stock trans cooler and A/C condenser
Old Oct 22, 2012 | 01:44 PM
JohnRios's Avatar
JohnRios
I purchased the Curt front hitch and had to REMOVE MY FOG LIGHTS, REMOVE BUMPER, REMOVE TOW HOOKS, and REMOVE SHIM PLATE. Took me over an hour and had a friend help me out but was able to save myself 500 bucks!
Curt Manufacturing - Front Receiver Ford Pickup / Excursion - 31114
Old Oct 22, 2012 | 06:01 PM
06Superduty's Avatar
06Superduty
I have a front receiver hitch made by Bodiak,( Bodiak Front-End Hitches) it clamps around the tow hooks. and I didn't have to remove the fogs. I use it for a bicycle rack, when towing the trailer, a step when working under the hood, and a bumper protector. Personally, I think it is easier to just learn to back up a trailer as it is to turn a vehicle around, plus the fact that it is harder to see where you are going if you have big trailer in front of you.
Old Oct 22, 2012 | 06:53 PM
acf6's Avatar
acf6
Where are you from in CT?
Old Oct 22, 2012 | 09:26 PM
DetailerDave's Avatar
DetailerDave
I made one similar to the one shown by pbeering. Mine has a flat plate with 4 bolts at the bumper mount, with a tube for a standard drawbar. I don't have a pic handy tho.
Old Oct 26, 2012 | 10:53 AM
DetailerDave
I took a quick pic with my phone. Pics of my truck are on my home computer.
Ford Truck Enthusiasts Forums - DetailerDave's Album: Garage - None
