Newbie: 56 Build Advice
I have just acquired a 56 F100 and am researching what should be done to acheive a safety (S) level restoration. So far in the build examples on the site, which have been very helpful, I see power brakes with disks up front, Toyota power steering, a rebuilt Y-Block (292?) - there is no engine in it today and I guess a 3 speed manual to be original. I would like to lower a bit for better handling - so perhaps mono springs to get down 3" or so. Seat belts of course. New wiring harness.
What are the other major items that I need to think through? I am trying to lay everything out before I turn a single wrench.
My use is as a weekend "handyman" truck, not a trailer queen. Light hauling of yard stuff from the nursery, friends furniture. Need to be able to keep up on the freeway at 60 or so for short trips of less than 75 miles. Need heater, don't need air. Mainly, just need something that is very, very reliable. Wife will be driving as well so that's where the power steering/brakes/ reliability come in.
Love to hear your thoughts on what has worked for you. Thanks for taking time to answer. Will start a build post once activity begins.
I second pictures now We love the pictures!
For safety: 3 point seat belts, Mid-fifty sells the anchor point for the shoulder strap. Also a dual chamber master cylinder. You'll need a new MC for disc brakes anyways, but the original ones just have one chamber, so if you loose fluid you loose front and rear brakes rather than just one or the other.
For better handling many people put in a Mustang II type IFS suspension system up front.
on
Quote:
Originally Posted by 76f350spercamprspeal
Welcome to FTE, Best Damn Forum EVER!
Here's How to Post Pictures:
1. Login to FTE.
2.Click User CP (In the Top Left Hand Corner)
3.(On the Left, There will be a list, The 5th Option Down, will say "Pictures & Albums) Click That.
4.Then, Click Add Album, Enter a title, and description, if ya want to.
5. Click Upload Pictures, Then click Browse, Locate the Files of your truck. (You can add 3 files at a time)
5. Click Upload.
6. Add a description to the individual pictures, then click save.
7. Add more files if ya want.
8. Click The Picture you want to post, it will give you two codes at the bottom, Right Click The Second one (It say's BB Code, Then Say's [IMG]http:blahblahblah...[/IMG])
Then, Once that is highlighted, Right Click, Then Copy, Then Paste it into your post.
You can add up to 30 Images in one FTE Post.
If, Ya need any help, Don't hesitate to ask.
Quote:
Originally Posted by old_dan
You can also go to the "Garage" tab and start an album right here on FTE. After you post pictures to an album, we can look in your album, but you'll also be able to "insert a picture" by pasting in a link to the picture in your album.
It seems awkward, but whenever you "insert a picture" to one of these threads, the forum is looking for the picture somewhere on the web (which is always available) rather than from somewhere on your hard drive (which isn't always available).
Quote:
Originally Posted By Jolly Roger Joe
Welcome to FTE!
Go to Image hosting, free photo sharing & video sharing at Photobucket and sign up for a free account. Then create an album for your truck. Upload any pics you want to post on FTE to that album. Have this album open on your computer when you want to post pics on FTE.
While you're making a post on FTE, select the pic you want to post from your Photobucket album. When the large version of the pic is open, right mouse click on it and select "View Image Info". The image info will be highlighted and will look something like this:
http://i285.photobucket.com/albums/l...ghtsafter1.jpg
Copy that highlighted info (right click / copy).
When you have the spot in your post where you want the pic to be placed, select the "Insert Image" icon at the top of the post (looks like a mountain) and paste (right click / paste) the image info you copied in the highlighted box (just shows "http://" when it opens).
Your pic will be placed in the post.
Hope that helps.
Here's a tutorial Bob put together: https://www.ford-trucks.com/forums/67...-pictures.html
1. Login to FTE.
5. Click Upload.
Welcome to FTE!
Hope that helps.
juang316
08-20-2013 08:04 PM
Gear Up
04-15-2013 09:58 PM
F3boy
10-20-2012 10:29 AM
