BRAKES STICKING!!!!
Old Sep 4, 2002 | 11:36 PM
F_150_hotrod's Avatar
F_150_hotrod
BRAKES STICKING!!!!
Old Sep 7, 2002 | 07:39 PM
jbulson's Avatar
jbulson
BRAKES STICKING!!!!
[updated:LAST EDITED ON 07-Sep-02 AT 08:55 PM (EST)] OOPPSS!!! Wrong forum!!! SORRY On my 76 f-250 hiboy, the brakes seem to be sticking(fronts). I have replaced the clipers and the problems persist.Here are some symptoms. I will be driving along and all the sudden my front end starts shaking, The brake pedal also gets VERY stiff. The shaking is a result of warpped rotors and the calipers sticking, But if I shut my truck off for about 5 minutes and then try to drive, the brake pedal is back to soft and there is no more shaking...Profanity Removed?!! I have looked inside my boosters vacume line for any sings of brake fluid but found nothing. I am sure it is the booster or master cyl. but I just wanna know if anyone has seen symptoms like this before.
Thanks in advance!!!
Old Sep 8, 2002 | 09:54 AM
edenroadmaster's Avatar
edenroadmaster
BRAKES STICKING!!!!
try replacing the rubber brake hoses on the front.
i have seen these balloon on the inside and do not let the fluid return to the master cylinder. the rubber lines are realitively cheap and its an easy fix.
dont forget to rate your fellow users
edenroadmaster
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
