Hard starts after running.
Old Oct 7, 2012 | 10:55 PM
Leemakesmepee's Avatar
Leemakesmepee
Since ive had my truck back its started up every time no problem. Even when its been a little chilly. But after you drive for a little while and then you park like to go into a store come back out like 10 mins later it will have a harder time starting takes about three tries.
What would be causing this? all my glow plugs and GPR check out and im getting the wait to start but its a type of on and off thing.
Old Oct 7, 2012 | 11:18 PM
fordpride's Avatar
fordpride
Sounds like ipr orings
Old Oct 7, 2012 | 11:27 PM
Leemakesmepee
Thing is when i had my new Hpop put in i got a new ipr from international. could the orings go bad that quick ?
Old Oct 7, 2012 | 11:28 PM
fordpride's Avatar
fordpride
How long ago was that ?
Old Oct 7, 2012 | 11:29 PM
Leemakesmepee
End of July early August i want to say.
Old Oct 7, 2012 | 11:35 PM
fordpride's Avatar
fordpride
Anything is possible.
Have you ever done injector oring ?
Old Oct 7, 2012 | 11:38 PM
Leemakesmepee
I have not. I had some work done on it about 2 months ago when it wouldn't start they replaced one injector though.
Old Oct 7, 2012 | 11:51 PM
fordpride's Avatar
fordpride
Get the truck up to temp and while sitting in park mash the go fast pedal to the floor it should rev up to 3k rpm's with out any issues. If it stumbles around 18-2000 and then shoot to 3k then you have bad injector orings
Old Oct 7, 2012 | 11:55 PM
Leemakesmepee
Ill try that tomorrow and let you know what happens.
Old Oct 8, 2012 | 04:42 AM
BRay09's Avatar
BRay09
Would the truck have fuel in his oil if the injector orings were bad?
Old Oct 8, 2012 | 07:33 AM
fordpride's Avatar
fordpride
No. You'd have oil in the fuel. Fuel psi 65psi HPO is min of 500psi so the oil would push in to the fuel system
Old Oct 8, 2012 | 01:39 PM
Leemakesmepee
Well i got her up to temp and i gunned it to 3k the first time it kind of stumbled at 2100 and a little white smoke came out. Then i did it again no stumble but again with a little white smoke.
The white smoke would be burnt oil ?
Old Oct 8, 2012 | 01:56 PM
BRay09's Avatar
BRay09
Are you sure it was white? You got that aftermarket HPOP on there... could just be extra fuel
Old Oct 8, 2012 | 01:58 PM
Leemakesmepee
But if it was extra fuel wouldn't it be black in color? it was white when it blew towards the cab.
Old Oct 8, 2012 | 02:17 PM
BRay09's Avatar
BRay09
Have someone ride in the bed when you take off. It would be easiest to tell that way
