2004 Exp. Suspension/Camber
Old Oct 7, 2012 | 11:30 AM
vietnamvet's Avatar
vietnamvet
Yesterday I had to get my air pressure checked. Tires on the car are fairly new and vehicle has 60K miles.
We noticed that the inboard side of the tires were nearly worn out. Upon further investigation, we noticed that the camber on both rear wheel is off.
The tire tops on both sides are tilted in and that is why the tires are nearly worn out.
My question is: Is there a common item that impacts both sides that could have bent/broke/or came loose that would cause this problem.
This is a very new problem since I have only had the car back for about 6 months.
It had a front end collision in November and I got the car back in February.
Any help would be appreciated. If there is a particular item I should look at, pictures would be a great help.
Old Oct 7, 2012 | 12:41 PM
alloro's Avatar
alloro
It doesn't have to be a single component affecting both sides. For example the ball joints can be worn on both sides, or the alignment could be out. Your best bet is to bring it in for an alignment. They will check the front end for wear, and if anything needs to be replaced first, they will let you know.
Old Oct 7, 2012 | 01:14 PM
vietnamvet's Avatar
vietnamvet
I agree however, just thought that something else happened in the interim. When they did the front end, they ended up having to change the tranny. Since it is a 4X4, and did not have anything wrong before, just a thought that they did or did not do something correctly or something else was damaged that wasn't fount. Will probably take in for Alignment tomorrow.
Old Oct 8, 2012 | 04:45 AM
Moto Mel's Avatar
Moto Mel
If a shop did the front end repairs they should have had the front end aligned before giving the truck back to you.
When the transmission was done, did they tamper with the torsion bars at all?
jspence105
Oct 27, 2014 07:58 PM
RedDirtLandscaping
Jul 12, 2011 01:00 PM
RedDirtLandscaping
Jul 11, 2011 09:29 PM
craziejoker
Sep 20, 2008 06:03 PM
95Ford4x4
Sep 4, 2007 11:06 AM
