460 cam
Old Oct 6, 2012 | 12:36 PM
twwtruck's Avatar
twwtruck
Question 460 cam
How radical can I go without having to change my stock valve train
Old Oct 7, 2012 | 10:28 PM
mark a.'s Avatar
mark a.
With any bigger cam you will need to check pushrod length, check for the right lifter preload, retainer to guide clearance, valve stem seal clearance. You can run stock rockers but I'd still check clearance in the rocker. Get the matching springs for the cam and put them in at the right installed height and check for coil bind.
Old Oct 8, 2012 | 03:46 PM
Beechkid's Avatar
Beechkid
In general, the cam grinder can advise you of what is the max lift before you have to change springs, etc...but as previously stated, always check even if they say it's ok.........
Jordan Acosta
Oct 4, 2018 05:29 PM
79f250_ranger_xlt
Feb 4, 2013 11:49 PM
mpc07005
Jul 17, 2012 09:09 PM
Blown 331
Feb 11, 2006 05:30 PM
TonyG
Feb 25, 2002 05:55 PM
