Bronco II Ford Bronco II
Thinking about 4.0
Old May 18, 2003 | 06:28 PM
nightcrawlermc's Avatar
nightcrawlermc
Thinking about 4.0
I'm thinking about putting a 4.0 in my 4WD '85 BroncoII. Will the transmission and transfer case that's already in it work? What other modifications will I need to make? Any information will be helpful. Thanks.
Old May 22, 2003 | 12:11 PM
jcharne's Avatar
jcharne
Thinking about 4.0
*bump*. I have an 88 and i would like to know this also
Old May 22, 2003 | 02:50 PM
benefital's Avatar
benefital
Thinking about 4.0
Ya i also have a 89 with an A4LD tranny which i want to put a 4.0.
Old May 25, 2003 | 10:53 AM
ShadowBronco2's Avatar
ShadowBronco2
Thinking about 4.0
If i knew i would let you know. I'm also thinkin of puttin a 4.0L in my 85 B2 or possibly rebuildin the 86 2.9L thats in it, but I'm thinkin of some Keith Black pistons and possibly a better cam or something. If it isn't gonna cost too much that is. Info on the bolt in for the 4.0L would be good.
Thanks
Old May 31, 2003 | 12:32 AM
bumpin_BII's Avatar
bumpin_BII
Thinking about 4.0
ya i need it for an 86 to. i have no choice on myne though. lifters finally quit on me and the rest of the engine is unrepairable without a rebuild so ill go to a 4 if anyone can give me advice though id love you for it.
Old May 31, 2003 | 09:28 PM
Bronco 1169's Avatar
Bronco 1169
Thinking about 4.0
Yes the 4.0 will work but it is hard but not too hard. i have not doin it but i am goin to soon . i have a 86 bronco 11 2.9 auto putin a 87 stick and a 94 4.0 so i really don't know if it will work but i will let yall Know.
Old Jun 22, 2003 | 06:49 PM
jayinco's Avatar
jayinco
Thinking about 4.0
I just converted my 86 B2 automatic from a 2.9 to a 4.0. I highly recommend this motor over a V8. The 4.0 will bolt right in! Even with a V6 the 4.0 will amaze you with the power. I must warn you to be on guard for more fuel consumption, I love the power and so I sacrfice fuel consumption. I got luckey and found a garage that had done a prior conversion, they almost didn't want to convert it but my BII's computer was an OBD1, the one they did prior was OBD2 and they had problems all through the conversion. Also prepare to drop about 4-6 grand on the total conversion, replace radiator, hoses, wiring, air intake box etc. When obtaining replacement 4.0 motor, it is VERY important to get computer and wireing harness. Good luck all!
Old Jun 22, 2003 | 08:12 PM
IamToyoftherm's Avatar
IamToyoftherm
Thinking about 4.0
Also prepare to drop about 4-6 grand on the total conversion, replace radiator, hoses, wiring, air intake box etc. When obtaining replacement 4.0 motor, it is VERY important to get computer and wireing harness. ........................In other words, best bet is to find a rolled over donor vehicle cheap and swap it yourself?
Old Jun 22, 2003 | 09:10 PM
jayinco's Avatar
jayinco
Thinking about 4.0
If you have the know-how and can read wireing schematics you'll do fine, this is not a project for the back yard mechanic. I looked into doing it myself but found a lot of potential problems-mostly by not having all the right tools and resources. If you do it yourself you'll save a bundle.
grease monkey
1983 - 2012 Ranger & B-Series
Dec 19, 2004 11:13 AM
78Explorer
Jun 19, 2004 04:59 PM
hammerdn
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Feb 10, 2004 10:34 AM
Little_E
15
Sep 15, 2003 06:05 PM
WC76TX
Jul 28, 2002 08:13 PM
